3ds Max Autodesk 3ds Max
Old November 11th, 2004   #1 (permalink)
Rick Eloy's Avatar
Default Problem with raytraced reflections and radiosity
Hey, m8s! This maybe a dummy question, but I ran into it just today...
I have a wood material with raytraced reflections. The problem is that when the reflection is off, the rendering comes out just fine. When I turn it on, it blows all raytraced reflections in the scene. Has anyone had the same experience?
PS: Using Max 6 with sp1
Rick Eloy
Rick Eloy is offline
Old November 11th, 2004   #2 (permalink)
abicalho's Avatar
Default Re: Problem with raytraced reflections and radiosity
Do you have a background color? If so, try setting it black.
Alexander
abicalho is offline
Old November 12th, 2004   #3 (permalink)
Rick Eloy's Avatar
Hum....worked. But why?
Rick Eloy
Old November 12th, 2004   #4 (permalink)
abicalho's Avatar
When the reflection hits the max depth, it then uses the background color instead of continuing the ray. With exposure control, the background color has a lot of energy because it needs to be inverted and considered in Floating point. This causes the problems you're seeing.
Ideally one should not use a background image or color, but instead model a billboard and apply a color/bitmap to it.
Alexander
abicalho is offline
Environment reflections? Brian Cassil 3ds Max 1 July 3rd, 2003 07:20 AM
Environment Reflections in Radiosity Lester Masterson 3ds Max 2 June 20th, 2003 03:02 AM
Setting Up Sky - Radiosity & Reflections Eric Autodesk VIZ 1 November 11th, 2002 04:33 PM
Radiosity and animation. Spongebob Autodesk VIZ 1 October 8th, 2002 04:09 PM
