Old December 7th, 2004   #1 (permalink)
ipdesigner's Avatar
Philippines  Send a message via Yahoo to ipdesigner
Default scanner variation
*i have this scanner HP model Scanjet 3500c (for pro, i guess), purchased awhile ago..first image attached is a sample output it gets, setting is resolution (ppi)=150, output type=millions of colors (24 bit). A yellow 'lines/stripes'. appears! most of the pictures comes out with the same results, even I increased the resolution, still the same. and takes a bigger file size! As sample, one image: resolution=150, 1197x1012x24b jpg = 1.62MB size!
second image from HP Officejet G Series (3-in-1, printer-scanner-fax machine) from other PC, not mine....gets a better quality!! with the same image size, but not sure about the resolution..
*Whats the problem on my scanner? Does the resolution plays the role?
Plsss help!.
ipdesigner is offline
Old December 8th, 2004   #2 (permalink)
Name: Wendell Dimaculangan
Default Re: scanner variation
If you've scanned it from a magazine, use the descreen function of your scanner to achive better result.
Wendelld is offline
Old December 8th, 2004   #3 (permalink)
ipdesigner's Avatar
*"descreen function", cant find this in my scanner...
*and mags and books take the same results, i think its not about the article type..
*btw, thnx!
A3 scanner plastic Hardware and Technical Discusions 0 October 17th, 2003 05:51 AM
