Autodesk VIZ Autodesk VIZ
Old February 8th, 2005   #1 (permalink)
vizwhiz's Avatar
Default Water Fountain - need the Water
hello There
how do you do Water look-alike Spray in VIZ without the particle spray utilities
i already have 6 physical fountains, now i just need to add the Water
(its a dry heat down here in Arizona, just add water)
any comments greatly appreciated
I DO NOT HAVE MAX SO THEREFORE I CANT DO THE PARTICLE SPRAY SYSTEMS
maybe The Boss Man will have to buy MAX but until Then i got to do This
with what i already have and/or dont have
Randy
vizwhiz is offline
Old February 8th, 2005   #2 (permalink)
Chad Warner's Avatar
Default Re: Water Fountain - need the Water
Have you tried the RPC fountains?
-Chad
Chad Warner is offline
Old February 8th, 2005   #3 (permalink)
vizwhiz's Avatar
Thanks Chad
no. They are not what i need, here is an Image of my doodle so far
i guess to be more specific That i already have the physical fountain modeled
(and rendered) so i need to make a mesh, probably 1 that falls over the edges
and 2 the other goes up and out (semi-spherical a bit)
i am looking thru the autodesk viz newsgroup search results for water at the moment
but i only need a still image so That simplifies my lack of understanding considerably
i found a Ted Boardman article so i might try to incoroporate That
any comments suggestions Ideas greatly appreciated
Randy
vizwhiz is offline
Old February 8th, 2005   #4 (permalink)
MJL Imaging's Avatar
United_States  Send a message via MSN to MJL Imaging
what if you lathed a spline around the fountain, added a material and maybe some PS work? or is that just a crappy idea? anyway, it's the first thing that came to mind. Good luck.
MJL Imaging is offline
Old February 8th, 2005   #5 (permalink)
abicalho's Avatar
Hi Randy,
Take a look at the GOFA WIP posts for mental ray on VIZDepot. Here's a link:
http://www.vizdepot.com/forums/showt...&threadid=1575
Tetsuya Ozawa (ozlime) explains how he did the waterfalls and they look absolutelly gorgeous.
Hope this helps,
Alex Bicalho
abicalho is offline
Old February 9th, 2005   #6 (permalink)
vizwhiz's Avatar
Alexander, Thanks i will check That out
MJL, so far i made up a cylinder, converted to mesh, subdivided
i need to fillet the top edge where the water goes over the side
but how to make a map that fits onto This is next question
Thanks for the Info and suggestions
Randy
vizwhiz is offline
C4D WATER SHADERS STRAT Cinema 4D 28 October 2nd, 2006 04:42 AM
Water from fountain jets!!! archkre 2D/3D Tutorials 5 May 5th, 2004 01:42 AM
Water Color Filter King David Photoshop 7 February 13th, 2004 12:00 AM
Water Fall Frosty Cinema 4D 6 July 23rd, 2003 02:42 AM
Liquid Cooled Systems?!! Erik Lund Hardware and Technical Discusions 6 July 9th, 2002 11:22 PM
