hello bis,
so .. warning...
there is 2 mode in dual screen :
the "real" DualScreen ...
that 2 screens = 2 desktops = 2 resolutions pixel
(exemple : 1600x1200 and 1024x768 for second..)
and the "false" dualscreen :
that windows only extend primary screen int o the second
you have only one screen (mega screen but one only)
(example : 2600x1200 and the resolution pixel is blocked.. you can't change the second screen..
so you must use same monitor and the same resolution on the two monitors..)
so alls softs run on False Screen mode..
but not lot of on real dualscreen ...
Actually Autodesk product (autocad)
can run in false.. and sometimes in real mode..
(test it !!!)
but ADT and Revit don't run for moment i think (i'm sure for revit not for ADT ..)
good day
edition PS : yes the problem that lot of software don't save windows position....!!!
Adobe product YES .. other .. no be ...
NEVIANS Cédric -=- FRENCH ARCHITECT D.P.L.G
Wood and Iron construct Specialist
and CG Architectural render
Autodesk ATC teacher (Viz)
Amapi Pro 7 and Revit user.
http://www.zonetectural.net
and expo at eOVIA user gallery
