Name: Travis Rhoads |
I am familiar with video cards that support two monitors, where there are two standard monitor plugs on the graphics card.
Question is this: My video card has a TV out as Secondary option. Does this mean that if I get the proper cables, I can connect another monitor to my video card using this port? I am trying to figure it out, as we have an extra monitor in the office, and I would really love to have a dual setup. Any advice or help would be greatly appreciated. Thanks.
I am trying to drink away the part of the day that I can not sleep away.
Name: Brian Zidovec |
well its hard to determine since I don't know what type of video card it is, my assumption is what will be produced on the screen would be the same as you see on your main monitor, so most likely its not ment for dual set up. So unless you want to test animation on NTSC/PAL colours with a TV, I doubt it will suit your needs.
Name: Eric Adams |
I would also think that if you were somehow able to get it to connect to a computer monitor, it would only be sending out a signal at the resolution suitable to televisions. I believe that's only like 720x486 or something of the sort.
If you really want dual monitors (which I highly suggest), why not try to pick up a cheap card that offers dual? Or, isn't there a way to have 2 video cards with the cheap one pushing the second monitor? |
Thanks guys,
I will probably end up buying a good dual monitor card and making the swap, i just wondered if it would work. After further review, the card has a receptor on the back, for what I am not sure. it is a white receptor, similar to the ones for the regular monitor plug, but the pin setup is different.
Name: travis schmiesing |
can you take a picture of the back of the card, and post it? ...or post a link to the video crd you have.
travis schmiesing |
#7 (permalink) | |
Name: Eric Adams |
in any case, you should be able to plug an adapter into it and connect a standard monitor to it. not sure if it will push duals, but you can in fact (with an adapter) plug a standard CRT monitor into that port.
#9 (permalink) | |
right now i am using nVidia Quadro NVS card that has one monitor plug coming out, that has a cable plugged into its only out port, but the cable splits into 2 so that i can run 2 monitors off of the single port. i imagine that option is built into the video card, and that you can not simply by one of these splitters, and plug 2 monitors in, but i don't know. i run windows xp using classic windows interface, rather than using the 'xp' skin that microsoft created (easy way to make the operating system look new), and i run my second monitor at 16 bit color resolution instead of 32. i beleive both of these help take some of the pressure off of my video card.
travis schmiesing |
CHG,
so you think that a second monitor hooked up to the DVI output, will work? I will have to try, and will post back after I have tried it out.
| Video Card Question | meatarian | Hardware and Technical Discusions | 5 | February 1st, 2005 06:01 AM |
| No Video Card Fast enough to run ADT?! | Aspiring Visualizer! | Hardware and Technical Discusions | 3 | October 24th, 2004 06:54 PM |
| Video Card recommendations | rozsadan | Hardware and Technical Discusions | 21 | July 25th, 2004 11:46 PM |
| Video card problem | azazel61 | Hardware and Technical Discusions | 3 | May 31st, 2004 11:25 AM |
| Video Card problem? | Jeff's Friend | Hardware and Technical Discusions | 12 | September 11th, 2003 05:33 AM |
