3ds Max Autodesk 3ds Max
Old February 20th, 2005   #1 (permalink)
Name: ray ray anderson
Default Making edges visible
How do I make edges visible when doing a quick render? I’ve tried to give the edges color in sub object mode, but that didn’t work. Also I tried the forced wireframe option but that only showed the edges and not the model itself.
Anyone, any suggestions?
rayray is offline
Old February 20th, 2005   #2 (permalink)
Ras
Ras's Avatar
Denmark Send a message via ICQ to Ras
Default Re: Making edges visible
Ink´n paint material
Regards
Ras
Ras is offline
Old February 20th, 2005   #3 (permalink)
Name: Herminio Jalocon Jr.
Philippines  Send a message via Yahoo to noi-pi
Apply Lattice Modifier to your object and play with the settings.
We manufacture modern antique furniture.
noi-pi is offline
Old February 20th, 2005   #4 (permalink)
jucaro's Avatar
Name: Juan Carlos Rosalejos
Philippines  Send a message via Yahoo to jucaro
Ink and Paint will only outline the general perimeter edges, AFAIK
Latice modifier will only render much like force wireframe but with width
If this is what you mean then its not that difficult.
Either you render the wireframe separately and make a composite or follow these steps
-select object you want to render edges
-edit mesh, use edge selection mode then select all edges
-click "Create Shape From Edges"
-select the shape you just created
-under the modify tab, click "Renderable" under the Rendering rollout
-enter desired thickness
-apply color or material
-render
-walla! you now have a visible edge render
BUT if you just want to make a quick render of the viewport in
Edged faces then maybe someone else knows how.
And, yes, you can also duplicate the object and put a latice modifier on the
other duplicate, but that would increase your polycount and thats
bad news if you have a very large scene.
MD8 Design Solutions
X3MFX Interactive Design Agency
DE MAX Design PTE LTD
jucaro is online now
Old February 20th, 2005   #5 (permalink)
v_wrangler's Avatar
Name: Roy Constantino
Japan
Another way is to facemap something like this...
(I think you've got something similar in the maps/misc directory...)
v_wrangler is offline
Old February 20th, 2005   #6 (permalink)
PiXeL_MoNKeY's Avatar
See my notes in the following CGTalk Thread on how to do wireframes using ink'n'paint. http://www.cgtalk.com/showthread.php?t=179112
Basically you use smoothing modifier set to 0 and set the ink'n'paint set to user smoothing groups.
-Eric
PiXeL_MoNKeY is offline
Old February 20th, 2005   #7 (permalink)
mallku's Avatar
Bolivia
http://www.spot3d.com/vray/help/VRay...tex_params.htm
is that what you need?
http://mallku3d.blogspot.com/
mallku is offline
glowing edges with v-ray cullen VRay Render 8 January 13th, 2005 11:17 PM
Making more topo lines sky AutoCAD/AutoCAD Architecture 3 November 10th, 2004 07:56 AM
Making Plugins / Addons to Archicad q4d Archicad 1 November 20th, 2003 08:34 PM
Glass (opaque edges) mbr 3ds Max 5 November 13th, 2003 08:48 PM
Need help with making slab Chanele Archicad 3 September 6th, 2003 05:11 AM
