Old May 25th, 2002   #11 (permalink)
adrian_dav
Guest
Posts: n/a
Name:
Originally posted by samp:
These results alre realy shocking me!
I'm going to buy myself a new PC this summer, and I allways thought that for stuff like VIZ4 I deffinately needed to go for the Intel Pentium IV !
But it seems that AMD is the better choice.
And with AMD I can maybe afford a dual CPU system
intel seems to be close behind amd when it comes to calculating radiosity at the same clock speed. nobody posted results for a p4 xeon 2.4GHz yet, but i assume it runs circles around the athlon MP 1670MHz(or 2000+ PR rating).
that would be a relief for me. i use a dual athlon system right now. it runs very hot and needs a lot of cooling resulting in nasty noice levels. no more amd chipset on my mobo please! i'd like working USB, shutdown windows despite the existence of a firewire card, less heat and more predictable RAM support.
it might have been just my tyan MP board, but it felt like an unfinished product from the beginning.
Old May 25th, 2002   #12 (permalink)
Greg Hess's Avatar
If someone posts the 2.4 Xeon. I'll post a Dual 2100+ MP and make them weep.
The higher intel goes, the faster amd catches up .
And yes I'm biased. My 1.8A northwood is slow as !@$(*7 compared to my AMD system.
Greg Hess is offline
Old May 25th, 2002   #13 (permalink)
Name:
Be very careful if you're going to build your own AMD system though. I would recommend Monarch Computer,.Game PC, etc. Not Xi though.
squid is offline
Old May 25th, 2002   #14 (permalink)
adrian_dav
Guest
Posts: n/a
Name:
the little chip war is the best thing that ever happened to us. i'm biased in both directions. i like AMD's raw FPU power and i like intel for being able to build a box that doesn't sound like a vacuum cleaner.
since i spent looooong hours near my machine the noise is a bit of an issue. at least i don't hear the airconditioner as much . do things get better with the new athlons?
Old May 25th, 2002   #15 (permalink)
Name:
Pentium 2.2A Northwood
Win 2000 Pro
Viz 4
512 megs of RDRAM
16 Minutes 16 Seconds
squid is offline
Old May 25th, 2002   #16 (permalink)
Greg Hess's Avatar
Noise is a problem regardless of which chip you go with. To solve either problem you need to do some research, and setup the cooling yourself. If your willing to do that, you can build dual systems with well under 35 db output. (Thats with 8 fans).
Currently my default 1.8A Northwood is AS LOUD as my dual 1900+ MP system.
So don't think that buying intel you automatically solve the noise problem . YOU have to solve the noise problem, AMD and Intel don't care .
I commented alot on this issue in one of the other dual athlon threads on this forum about jeff's system. The easiest solution is replacing all the fan's in the case. Throw in some adjustable rpm fans, and you can tweak the noise levels and get the same quiet ambient hum throughout. This of course requires massive heatsinks on the cpu's, as you need to cool more with surface air then airflow.
If noise is still a problem, there are a variety of insulators you can purchase to cut off front and top and side noise. I would recommend if you do this, to greatly increase the ventilation out of the rear of the case, to help hot air escape. Insulation also creates heatbuildup and nullifies all the advantages (cooling wise) of an alumnium case.
The most advanced and technically challenging setup would be a water cooling system, contained within an insulated box, with an external resevoir and monitoring system to completely remove any and all fan sounds from the case area.
The new AMD systems now include a downclocking system to reduce core temperature, just like intel has with the p4's. With the burning up problem solved, I really don't seen any reason going with an intel solution, unless your forced too, or have a specific program that utilizes SSE2.
Probably the quietest system you could build WITHOUT rpm adjustable fans would be...
A case using an enermax whispher powersupply, with 4 x pablst 16 CFM fans (18 db), with two silverrado's (around 60 USD each) as cpu coolers.
That would then make the loudest part of the computer the rom and hd's.
Old July 2nd, 2002   #17 (permalink)
Dave Buchhofer's Avatar
Name: Dave Buchhofer
Red face
p4 1.5 (1.495 GHZ)
Windows 2000 Pro
Viz 4
1024 megs (Scsi 160 on swapfile)
Elsa Gloria III
Radiosity time:
24 Minutes 51 Seconds
Render Time:
0 Minutes 22 Seconds
Painful.. But about to become a hand-me-down as the new dual 2100 boxx's show up )
Dave.
TD / EwingCole DMG
Dave Buchhofer is offline
Old July 2nd, 2002   #18 (permalink)
Dual AMD 1.2MP
Win 2k
Tyan S2462
1gig
Radiosity time:
12 Minutes 18 Seconds
ZepSOFD is offline
Old July 2nd, 2002   #19 (permalink)
HeDaCoM's Avatar
Spain Send a message via ICQ to HeDaCoM
I've tried my old DUAL PII-450, 512MB RAM
ASUS P2BDS
VIZ4: 31 min 27 secs
MAX5 beta: 18 min 50 secs
I won't upgrade any hardware... just software
regards
Héctor D. Corcín
http://www.iruditek.com/hedaweb
HeDaCoM is offline
Old July 29th, 2002   #20 (permalink)
matt_vinoir's Avatar
United Kingdom  Send a message via MSN to matt_vinoir
dual 1800 xp AMD
1.5 G ram
GF4 Ti4600
Time 10 min 09
hmmm adrian had 3 gig of ram for 6 sec quicker time, gutted!!
matt_vinoir is offline
