Old July 29th, 2002   #21 (permalink)
adrian_dav
Guest
Posts: n/a
Name:
Originally posted by matt_vinoir:
hmmm adrian had 3 gig of ram for 6 sec quicker time, gutted!!
the amount of ram does not have any influence on the time needed in this case. it is a small scnene even after viz is done "meshing" it. more ram would be useful for a large scene to avoid swapping data back'n'forth between memory and hard drive.
i just don't have the time to take the ram out of the box each time i render a small scene .
best,
a
Old July 29th, 2002   #22 (permalink)
matt_vinoir's Avatar
United Kingdom  Send a message via MSN to matt_vinoir
i'm not rubbing it in adrian! I'm just amazed, as all you here is viz will eat all the ram you can chuck at it in evrey circumstance, i didn't realise it wasn't the case all ther time
matt_vinoir is offline
Old July 31st, 2002   #23 (permalink)
adrian_dav
Guest
Posts: n/a
Name:
... and i didn't intend to come across as one of these "mine-is-bigger-than-yours RAM-machos" . the RAM requirements of viz4's radiosity process are imense. autodesk should advertize VIZ to consumers by having put RAM-sticks put into cherio boxes .
i always considered 1gig RAM overkill, but a typical rendering size of 4000x3000pixel in conjunction with the RAM-eating radiosity solution made it neccessary to get more.
greg_hess mentioned in another thread on this forum that windows is limited to 2gb RAM per thread anyway. not much room to expand :-(. we better watch the polys and skip the chamfer and fillet tools from time to time .
best,
adrian
Old August 1st, 2002   #24 (permalink)
Dave Buchhofer's Avatar
Name: Dave Buchhofer
Finally got the new box's in! the word is
9:23 radiosity
Dual athlon 2100's. out of the box
haven't tried to tweak them yet. unfortunately 1 of the 3 has this little thing where if you install VIZ, it wont boot! such an annoying thing.
Dave.
TD / EwingCole DMG
Dave Buchhofer is offline
Old August 2nd, 2002   #25 (permalink)
coupe333
Guest
Posts: n/a
Name:
Win XP pro
Dual AMD 1800mp
MB: asus A7M266-D
Ram: 1G
Vga: GeForce 500 Ti
Radiosity Time: 0:10:05
Rendering Time: 0:00:13
Old August 27th, 2002   #26 (permalink)
Seems that this thread is dead, but here is my info.
Dell Dimension 4100
CPU: 1000MHz PIII
number of CPUs: 1
RAM: 512MB
motherboard: don't know - Dell
Time: 23 minutes, 46 seconds
Eric Adams
http://particlerealities.blogspot.com/
Eric is offline
