Old November 30th, 2005   #10 (permalink)
JamesTaylor
Default Re: vray dr vs. backburner
gary,
as mention by Kippu, mapping your networked drives properly and consistently across each machine node should remove the need to copy maps to each local machine, alternatively you could use unc paths but that may be more harssle on a large scene.
The buckets that render darker when using DR shouldn't happen, i've suffered this previously and it turned out i had different version of vray installed on different machines.....could this be your problem? After making sure i had the same version across all machines its never been a problem.
James
JamesTaylor is offline   Reply With Quote
