3ds Max Autodesk 3ds Max
Old March 14th, 2005   #1 (permalink)
treddi's Avatar
Switzerland
Default [help 3dsmax] How to reflect on the ground
First of all I would thank you for your help. I am a 3dsmax beginner so pardon me if I ask something that is obvious for you.
What I want to obtain is showed in the image attached: a reflection on the ground that smoothly disappears in a white ambient (I made the attached example with photoshop).
Can you kindly explain to me how to do that with 3dsmax with a plane and a box?
Thank you again for your patience.
Treddi
treddi is offline
Old March 14th, 2005   #2 (permalink)
DennisHolland's Avatar
Name: Dennis de Priester
Netherlands  Send a message via Skype™ to DennisHolland
Default Re: [help 3dsmax] How to reflect on the ground
Hi there,
Don't bother asking around, it's saves you a lot of aggrevation, especially when your just turned to MAX....
the easiest way is to (hit m) and pick a raytrace-material in materialbrowser, turn on 'reflections' and adjust the settings in your maps rollout (0 = no refl. 100 = ultra refl.). You should surf the tuts at www.3dcafe.com for learning the basics.
Good luck,
Dennis
__________________________________________
PRIESTERMEDIA
3D Visualisaties & Presentaties
Rotterdam, the Netherlands
DennisHolland is offline
Old March 14th, 2005   #3 (permalink)
treddi's Avatar
Switzerland
Dennis, thank you very much: I'll try now.
treddi is offline
Old March 14th, 2005   #4 (permalink)
manta's Avatar
add a gradient to you reflection
manta is offline
Old March 14th, 2005   #5 (permalink)
manta's Avatar
like this...
manta is offline
