| Lightscape Autodesk Lightscape |
Name: David Billo |
I read most, if not all, of the previous posts regarding problems with LS and XP. The general consensus seems to be:
1. Video drivers may be culprit - try different versions or use command line. 2. Large file sizes may be culprit - try merging 3. Corrupted blocks, textures, etc. may be culprit - try removing 4. Lightscape can be flaky at times, but is worth the trouble for the results you get. This is all new territory for me, new to Lightscape, new to playing with video drivers, but looks like I'll need to get my feet wet. I'm going to include my specific problems in case someone has any additional experience or ideas: Lightscape v3.1 (purchased last year) Windows XP Pro SP2 Athlon 64 3500+ 1 Gig Kingston HyperX BFG 6800 Ultra NVidia driver 6.14.10.6693 I installed, but did not authorize my copy. Generally, LS opened and ran fine. I had only the tutorials and one render job I did last year on my old box (Pentium 90, ATI Graphics Xpression -HAHAHAHA! - didn't make any money on that one!) Orbiting wireframe and shaded LP and LS models is *very* fast! Processing solutions and raytraces is also fast. Issues: All files opened would crash when selecting 'shaded&coloured wireframe' or 'hidden line' display modes. Plain 'shaded' or 'coloured wireframe' were fine. A few files crashed when loading textures. When making changes to processing parameters, I would get a message about not having enough memory (available memory was a negative number?) but everthing seemed to work regardless. Sorry I was not more observant about this. When opening lightscape, occasionally the view window did not completely generate leaving a stretch of desktop visible at the bottom, however loading a file fixed this and occupied the full area. When initially clicking to orbit a model, there is sometimes a slight delay (2-3 seconds) before movement starts, however, once the model starts moving, I can tilt-n-whirl as fast as I wish. After stopping orbiting and releasing the mouse button, there is, again, a delay before the process ends. This also occurs in another app which uses a shaded OpenGL window for displaying and orbiting a model (Datacad11 O2C). Tried running in various compatibility modes with no change. That's all I observed in a short time. I've uninstalled and plan to re-install and see if anything gets fixed, then authorize the program. (see my other thread/post about getting dongles) db Last edited by dbillo; March 22nd, 2005 at 07:29 AM. |
#2 (permalink) | |
As you have observed you have classic driver issues. Relatively stable drivers can be found for XP, as I use it. I still use a two or more year old nVidia driver since in WORKS. I have no interest in trying another. But one issue you cannot avoid is that you bought LSv3.1, because v3.2 was just more stable. I forget what else was added to v3.2. But, yes, LS does not like XP, so big processes should be done with the commandline utilities. They can be SO FAST anyway. LS OpenGL is great, I got spoiled by it. Good luck with it. |
itīs still such a shame that LS is not supported anymore. instead we have this !"§$%&!$"&/ radiosity engine in max
www.purerender.com architecture. vision. emotion |
#5 (permalink) | |
Name: Christian Bauer |
The cmdline tools are really fast and the few steps in the workflow, which have to be done in the GUi don't hurt. it's a shame that discreet needed three releses of MAX/VIZ to integrate adaptive subdivisions... and it's a shame that max7.5 will be only available for subcribers
[see.] |
#6 (permalink) | |
Beeeee! |
#7 (permalink) | |
Name: patrick anderson |
I run XPsp1 with a Nvidia quadro 750. I havent had any problems with using LS at all. Oops, I have had problems with the library blocks but not actually working in it. My blocks seem to have missing faces
#10 (permalink) | |
Name: David Billo |
| Lightscape Scripts for max | molson | Scripts | 10 | July 25th, 2008 06:39 AM |
| Trees in lightscape | tercoplo | Lightscape | 9 | July 5th, 2004 04:45 AM |
| lightscape versus max | aluigi | 3ds Max | 2 | November 12th, 2003 03:59 PM |
| lightscape to be retired | stephen gilbert | Lightscape | 14 | December 22nd, 2002 11:11 AM |
