Old March 23rd, 2005   #1 (permalink)
bully712's Avatar
Question Vray, Maxwell...................??
I'm getting to the point where it's frustrating to see all these awesome images created with Vray. ( I just want to be like everyone else....... lol )
I want my company to purchase Vray, and the Boss knows this. He also knows about Maxwell. I got a few questions:
1. Should we purchase Vray, or wait until Maxell? ( Maxwell's still in it's early stages right? Meaning they're still working out bugs )
2. If Vray, which version? Basic or advanced? and what is the difference ( other then price )
On my own, I was going to purchase the Vray basic, because I can't dish out $700 right now. Will Vray Basic give me what I need?
wireboxdesign.com
rendering the imaginative
bully712 is offline
Old March 23rd, 2005   #2 (permalink)
DennisHolland's Avatar
Name: Dennis de Priester
Netherlands  Send a message via Skype™ to DennisHolland
Default Re: Vray, Maxwell...................??
Vray basic will give you what you need...a renderer. But the great looking images are mostly created with the advanced version. I believe 1.5 is just out on the market but I'm not sure about it.
About Maxwell? There are a lot of speculations about the new render-engine and the samples, made with it, are great but not the explicit 'vray-look' as you see very often. Maxwell is campaigning their realworld lighting calculations and all, but I haven't seen any vray-style 3D-renders yet.
It's just up to you, what you prefer. The famous vray-looks or niche lighting calculations. Since Maxwell is about to release their first public-version, there probably will be some minor annoyances to report, vray is kinda fine-tuned by now.
Good luck with it.
Dennis
__________________________________________
PRIESTERMEDIA
3D Visualisaties & Presentaties
Rotterdam, the Netherlands
DennisHolland is offline
Old March 23rd, 2005   #3 (permalink)
Craig Ramsay's Avatar
You might be interested in the new rendering method that Vray has which gives very similar results to Maxwell. It is only available in the advanced version at the moment.
Craig
Craig Ramsay is offline
Old March 23rd, 2005   #4 (permalink)
Rick Eloy's Avatar
Have you tried VRay Free? It's a good start.
But keep one thing in mind: those awesome images you see around are not awesome because of the rendering, ok? If you use 3ds max (and I'm asuming you do) you can create incredible images using radiosity, especially in arch viz. Check out Chen Qing Feng's work, done with radiosity (some on Lightscape and the most recent on Viz).
Rick Eloy
Rick Eloy is offline
Old March 23rd, 2005   #5 (permalink)
Maxer's Avatar
Maxwell is still in Alpha testing and some of the problems with it right now are:
-no sub surface scattering
-little if no network rendering support
-day lighting setup is still unreliable
-only get 4 cpu licenses and the cooperative rendering setup still isn't working properly
-it's incredibly slow but this will change as it is developed
-can't render any high resolution images, doesn’t support anything above 2000x2000 pix.
-it will crash Max every time you try and open a new file
There are more but I can't remember them right now. Don't get me wrong, Maxwell will be a spectacular renderer once it's out of the testing phase. I'll make a prediction that most if not all render engines will be obsolete once it's on the market. They will all be trying to catch up to what Maxwell can already do, or simulate the look that Maxwell gives you. Unfortunately it's not going to be ready for several more months, and when it comes out you’re going to shell out $1000 for a program that only gives you limited licenses. Vray is probably your best bet for now.
Maxer is offline
Old March 23rd, 2005   #6 (permalink)
manta's Avatar
I don't know, I have mixed emotions on this whole thing, its always going to take longer to do a physically accurate lighted scene, as opposed to faking it, which ever way you happen to do it i.e. QMC, irradience maps etc... and I don't think unreasonable deadlines are going to suddenly go away...
With that said, computers get faster all the time, with dual cores comming out soon, which can turn your dual machine into a quad, so something that takes 4 hours to render today, might only take 2 hours then...
But I do know that it will be at least a year before I even look at Maxwell...
manta is offline
Old March 23rd, 2005   #7 (permalink)
bully712's Avatar
Thanks to all that responded. Everyones advise is great. Vray for now is the answer. Maxwell can/will be a upgrade once it's out and about...
I use viz 2005 and I like the result I get using the skylight, but it takes forever, as everyone already knows this. I was hoping that there was an option in Vray that would have the same effect as the skylight, but render a little faster, or it's just the fact that it takes forever no matter what you use.
With deadlines ( like everyone has ) I usually fake the lighting, which I can render a scene out in a few mins, but I'm going to start adjusting my lights to where I can render over night to get better results.
wireboxdesign.com
bully712 is offline
Old March 23rd, 2005   #8 (permalink)
manta's Avatar
Like Rick said, download Vray free. I use it all the time, and it probably is faster, using irradiance maps, than using the skylight in Viz...
make sure you check both (on) in the indirect illumination section, and the skylight (override max's) in the enviroment section, to get the look you want.
manta is offline
Old March 23rd, 2005   #9 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
i never really considered the skylight system to be slow, but i have not used extensively.
also, i am not sure if this deal is still going on.... but, i think if you buy maxwell now, you get it at a greatly reduced price. you also get the official release when it comes out.
travis schmiesing
crazy homeless guy is offline
Old March 23rd, 2005   #10 (permalink)
bully712's Avatar
Unless I'm using it wrong, but I don't think you can, or can you. I did a test the other day to see what kind of effect that it would have on my rendering. I created an empty box, with a store front window system on one if the walls. I then created a Skylight outside the windows.
Do you know what... Now that I had a 1 second brainstorm, I think I know what I'm doing wrong. The rendering dies when I turn on shadow casting with the skylight. I'm assuming I should use the skylight for the main light, and have a second light for casting shadows... I'm I right or wrong with this assumption?
I like the shadow effect the skylight provides. What would be a good shadow casting light to achieve the same look?
wireboxdesign.com
bully712 is offline
Ten vray questions steve VRay Render 10 September 13th, 2008 10:20 PM
Maxwell, Vray, C4D, Final Render Comparison mbr Other 3rd Party Renderers 4 December 1st, 2004 02:03 AM
Vray and Brizal Rio plug in Chris Potts Other 3rd Party Renderers 7 September 16th, 2004 02:01 AM
about Vray versions and VIZ 4.2 salf VRay Render 8 March 2nd, 2004 03:47 AM
VRay against Vray and ... Sergio VRay Render 15 May 30th, 2003 09:09 AM
