Old September 20th, 2002   #1 (permalink)
alkion
Guest
Posts: n/a
Name:
How can it be?my dual amd mps are suppose to run at 1,9 but the bios says they run at 1,6.The motheboard manufacturer says -asus- that its amd mp ready . The jumpers seem to be in the right place but stilll....the processors run at 1600 Ghz
what is going on?
Old September 20th, 2002   #2 (permalink)
Ernest Burden's Avatar
Name: Ernest Burden III
Are you saying the processors should run at 1900 because they are called 1900? If so, you should know that the later-day AMD Athlons are name for the 'relative performance' and not their actual clock speed. In other words, a model 1900 should run at about 1.6G
If you got a model 2100 expecting 1.9G, then it would obviously be a hardware issue. I have found that as long as the BIOS is up to the a certain speed, changing AMD CPUs is plug and play...but I have not messed with a MP system yet.
But I will!
Ernest Burden III
AcmeDigital
architectural rendering
Ernest Burden is offline
Old September 20th, 2002   #3 (permalink)
alkion
Guest
Posts: n/a
Name:
yeah that makes sence thank you E b
