| Autodesk VIZ Autodesk VIZ |
Name: Nick Ladd |
Hello everyone. I'm a long time lurker and first time poster. Right now I am actually learning VIZ 2005 (in addition to ADT) so please forgive me if my question is absolutely stupid. Here what is happening:
First off, I created a model in ADT (AutoCAD Desktop) and then linked it to VIZ. I went to assign a wall material and instead of only assigning the material to the wall (editable mesh) that I had selected, it assigned it to all walls in the model. I think that it is doing this because when the walls were created in ADT they were all created using the same wall style. My question is how I can override this so that I can assign different materials to different walls? Are these objects automatically linked somehow in VIZ when they’re imported from ADT? Thank you in advance for your expert guidance! Nick Ladd |
Hi,
if you imported the dwg/dxf in max with all walls attached or grouped, you have to break it apart. When attached, you have to assign material ID's to each part you want your materials on. When the walls are just grouped, you have to open up or ungroup them (group > ungroup or open) and your set. Both requires some searching for the right solution, but one of them works for sure and is the most easy way to solve your probs. Of course there are other solutions but for now just do (1) Attached: assign material ID's or (2) Grouped: ungroup or open up. Good luck and if you're stuck just shoot...
__________________________________________ PRIESTERMEDIA 3D Visualisaties & Presentaties Rotterdam, the Netherlands |
#4 (permalink) | |
Name: Nick Ladd |
Thanks! Nick Ladd |
| 3ds max file linker question | skippy | 3ds Max | 4 | January 17th, 2005 11:02 AM |
| Help! Materials For Render Needed | Al_Zyma | AutoCAD/AutoCAD Architecture | 3 | August 20th, 2004 01:12 PM |
| Composite materials and site question | Tommy L | General Discussions | 0 | July 8th, 2004 08:09 AM |
| Can i use 2 or more materials on just one shape? | salf | Autodesk VIZ | 26 | February 25th, 2004 02:37 AM |
| Materials forum... | Tonsgaard | Suggest a New Forum | 0 | August 19th, 2003 01:42 AM |
