Old April 4th, 2005   #1 (permalink)
Richard McCarthy's Avatar
Default How do you convert PDF to DWG??
Hi everyone, just a question... does anyone know how to convert PDF to DWG??
Don't mess with my hat !!
Richard McCarthy is offline
Old April 4th, 2005   #2 (permalink)
3dp
Name: david pinnington
Bahrain
Default Re: How do you convert PDF to DWG??
to my knowledge you don't
one of the project i work on has a intranet withich uploads plotplot files and pdfs
i go with plot files and use a viewer
then again you may be able to open it via illustrator and save as acad
years since i used illustrator but i know it will read some acad
can i have everything louder than everything else please
3dp is offline
Old April 4th, 2005   #3 (permalink)
Found a way, but it isn't the most efficient and accurate way.
1. Open it up in Adobe Illustrator
2. Export it to DWG
Problem is a lot of line is approximate of original lines.. it uses hundreds of lines to construct one line.
Old April 4th, 2005   #4 (permalink)
Yeh I want to open up this PDF file which is a site drawing (originally DWG) exported to PDF. I guess the original draftsmen doesn't want to share this drawing so he exported to PDF.
Old April 4th, 2005   #5 (permalink)
GI Dude's Avatar
Mexico
I've done the same, and it works fone for me, the only comment i have, is that requires some time, dependig the amount of RAM that you have...
I believe is the only way to do it...
Alex Guzman
GI Dude is offline
Old April 4th, 2005   #6 (permalink)
mbr
mbr's Avatar
Acrobat? Don't know, dont' have it, never used it, but I've always heard good things about it.
But yeah, that's what we do when we send acad files and don't want someone using them - send a pdf.
mbr is offline
Old April 4th, 2005   #7 (permalink)
Name: Gerald Hightower
I've not used it myself...but my cohorts report that this works.
Good luck.
Free:
Ghostscript and GhostView (GSview)
http://www.cs.wisc.edu/~ghost/
GeraldH is offline
Old April 4th, 2005   #8 (permalink)
This just in...
...a little more specific info..
Get Ghostscript and
GSView here (scroll down to Windows):
http://www.cs.wisc.edu/~ghost/doc/AFPL/get814.htm
Install Ghostscript then GSView.
Run GSView.
Open the PDF.
Go to Edit menu and pick Convert to vector format.
Save DXF
Open DXF in AutoCAD.
If it is not a raster it will show up (might need to zoom extents). Note
that the scale will be off, so if you have a dimension use SCALE reference
to fix it.
GeraldH is offline
Old April 4th, 2005   #9 (permalink)
vizwhiz's Avatar
Richard
here is a link to some software That can convert raster to vector
http://www.gtx.com/
hope This helps
Randy
vizwhiz is offline
Old April 4th, 2005   #10 (permalink)
nolanleblanc's Avatar
United_States  Send a message via MSN to nolanleblanc Send a message via Yahoo to nolanleblanc
Smile Re: How do you convert PDF to DWG??
Lately, we have been hearing more of this very question - how can I convert my PDF to CAD? GTX software works on many raster formats, but depending on how the Acrobat (PDF) file was originally created, it may very well contain some type of TIFF file. The trick is exporting the TIFF data to where you can do something with it (e.g., load it into GTXRaster CAD to re-vectorize it).
Adobe Reader V7 does seem to have a Picture Tasks plug-in, but it only works with "picture tasks-enabled" PDF files and therefore does not seem to be consistently available. There are other ways (e.g., "Snapshot") but you risk having an unusably low resolution. You need at least 300 DPI in order to have adequate raster to vector results.
You may be able to get a printer driver that prints TIFF files. This can be useful, but you want to make sure that you save it as a bitonal/binary (black and white) image and, when thresholding from color or gray to black and white, you don't "dither" the results or (again) the TIFF will be of ery limited use. You want nice solid black lines, and a dithering threshold will put many holes in the resulting raster data.
Once you have a black and white (binary) TIFF, you should be able to use raster to vector software, like GTXRaster CAD PLUS, to import the TIFF and convert the raster back into vector.
As we're always trying to make things easier, we might come up with a better way of doing this - you never know!
Hope that helps!
//\\//olan
> to DWG??
nolanleblanc is offline
convert 4:3 to 16:9 widescreen Jim Mann Compositing Software 7 April 15th, 2008 04:33 PM
maya dwg problems cat Maya 3 March 12th, 2005 05:32 PM
AUTOCAD dwg file convert to PDF file Chris Potts AutoCAD/AutoCAD Architecture 9 October 8th, 2004 01:42 AM
dwg to max6 problem alzain 3ds Max 12 September 4th, 2004 10:34 AM
EMERGENCY - AutoCAD --> PDF to scale.. mzagorski AutoCAD/AutoCAD Architecture 8 May 26th, 2003 02:47 AM
