Old April 17th, 2005   #1 (permalink)
Tommy L's Avatar
Default roof pitch
Im designing some houses in the tropics and have been informed i need a roof pitch of 22 degrees minimum because of the monsoon. Ive done it at 18 degrees at the mo' and really dont want to change it. I know theres a few architects that use this forum that will have designed in the tropics (this ones in Goa, India) and i just wondered what their opinion is.The eaves have massive overhangs so i dont see the problem. Help would be very much appreciated.
Cheers, Tom.
Tommy L is offline
Old April 17th, 2005   #2 (permalink)
Malaysia
Default Re: roof pitch
Just something to share,
Massive Overhangs is not the issue. If you are using roof tiles or slade, rain water might slip through between the overlapping tiles at a low pitch angle. 18 is considered low. Moreover, high angle pitch provides bigger volume roof space, hence, natural cooling. In Malaysia, 22 -23 degree is acceptable since high density rain comes in at an angle at high speed.If you are not using tiles, say metal sheet roofing, then theres no problem, i guess.
edri is offline
Old April 17th, 2005   #3 (permalink)
hi tommy
i lived and build 20 years in india
first overhang is not the mayor issue
ventilation / and rain are. you have 100 % humitity
and rains of 50 mm/hour and more, so to get rid of the water
and have good crossventilation is most important
i have seen many working flat roofs. metal as in australia is rarely used tiles are not of very good Quality.I would very carefully listen to the local Architect and follow their local experience. also think about condensation if the houses are
Aircontitioned 100 % Humitity at 35 degrees exteriore
and inside 22 d is a mayor proplem dampness condensation on the inside of the walls and windows
hope its of some help
Videha is offline
Old April 17th, 2005   #4 (permalink)
Sawyer's Avatar
You are very lucky. I traveled in Goa & it is one of the neatest places I have been. I hope you get site visits. Post pictures if you can.
Do keep in mind that the monsoons are very severe. Design to them and the worst case conditions but do seek local experiance it will trump everything else.
Sawyer is offline
Old April 18th, 2005   #5 (permalink)
Tommy L's Avatar
Smile Re: roof pitch
Much appreciated guys. Its a long time since i was at school and i wasnt considering wind driven moisture (thqnks edri). Cross ventilation is all sorted, minimum ceiling heights are 3m, going up to about 6.5m max. Have used modelling all through the design process so will post some images in WIP.
PS, yep, site visits and progress visits included
Tommy L is offline
How do you model a roof? Gnarly Cranium 3ds Max 30 June 5th, 2008 11:43 AM
Roof Edge Style Seperate Render Material? Al_Zyma Autodesk VIZ 4 November 8th, 2004 05:06 AM
How to create thached roof ksampath 3ds Max 5 July 2nd, 2004 11:39 AM
Changing default Roof Slab Angle? Alex Ryan Rubio AutoCAD/AutoCAD Architecture 2 June 25th, 2004 03:07 AM
roof tile mapping brehaut Cinema 4D 4 April 26th, 2004 09:39 AM
