*guys, im experiencing some problems with my PC right now, i cant run more programs at a time, e.g. photoshop, 3dsmax, autocad, YM..etc..there's a prompt coming that my pc is 'running slow' thus i SHOULD have to close some of the programs. i checked with my DRIVE C. cap. and this i have discovered. can somebody explain why is this happening? i didnt make any updates before. does WIN XP update itself automatically?
![]() Last edited by ipdesigner; April 19th, 2005 at 09:37 AM. |
Name: George Edgard Corrêa Cantanhede |
Your drive is full. You need to empty at least one third of your HD to make the programs back to work again. The programs you see as XP hotfixes are updates and bug fixes of microsoft, if you are not making the update manually your Windows must be ready to make automatic updates.
Name: travis schmiesing |
those are patches that windows updater installed. you can turn on and off windows automatic update in the control panel i beleive. you don't have a lot of hard drive space, you probably need to clean out your temp directories, and internet cache directories.
also, about once a month, clean out this directory.. c:\windows\prefetch\ defrag your hard drive. don't use more virtual memory than you actual need. i would use the same as your ram. ....add more actual ram. uninstall any programs that you have not used in the past 6 months. i also recomend switching to windows classic interface. 3dluvr has a tutorial on how to roll back windows xp skins, so that it looks like windows 2000. it will help your system run faster. hope some of these help. also, if you are not going to uninstall any of windows patches, you can delete the files in the windows directory that are shaded blue, and read something like ... $NtUninstallKB885836$ these are the unistall files for the windows system patches.
travis schmiesing |
#5 (permalink) | |
*meaning, that i have to delete all the files in this folder? |
#6 (permalink) | |
Name: Stephen Leworthy |
nope, windows updates aren't compulsory, but advisable. also, if ur going to defrag make sure you run it in SAFE MODE first.
and why not just invest in some extra HD space? it's literally only a few $$$ these days. will save you all this hastle. |
#9 (permalink) | |
travis schmiesing |
| URGENT: need to upgrade for ginormous project! | Gnarly Cranium | Hardware and Technical Discusions | 41 | February 2nd, 2007 03:59 AM |
| URGENT: Freelance artists required for 2D Floor Plan rendering | paulroy | Job Board | 1 | September 9th, 2004 09:27 AM |
| Urgent help for Animation | maurocaruana | Autodesk VIZ | 7 | August 22nd, 2004 05:50 AM |
| Urgent, computer specs | isagreg | Hardware and Technical Discusions | 14 | April 29th, 2004 09:54 AM |
| Car blueprints needed!!! URGENT | Rick Eloy | Off Topic | 7 | December 3rd, 2002 02:35 AM |
