Old April 21st, 2005   #1 (permalink)
Default Blowing up images --- HELP!
Hi everyone,
I have to repoduce a rendering for a billboard ad (about 96"x168" @ 50/75 dpi) and was wondering if anyone knew of any software that will allow me to blow-up a rendering/image without losing too much resolution.
I'm having problems rendering it so big in 3ds max, keep getting "out of memory" errors, so i've decided to render it at a lower res and see if i could blow it up without losing too much resoultion. I can swear that i read something about a software that does this very well on this site in the past.
If anyone has any knowledge of this, can u please post ASAP. Also, if anyone can tell me if 50 dpi is enough for this ad, that would be great as well.
VCRUPI is offline
Old April 21st, 2005   #2 (permalink)
vizwhiz's Avatar
Default Re: Blowing up images --- HELP!
look for bigrender or bgrender on This Page
http://www.scriptspot.com/Main_Scrip...nder&Sort=Name
or direct i Think is
http://www.scriptspot.com/download.asp?ID=2062
maybe render the sections @ 100 dpi or 150
i just used this .ms about 3 weeks ago to render
a 36" x 24" plotfile @200 dpi i too was getting a "out of memory" error
This will create 2x2 or whatever you select sections but beware
There WILL BE A 1x PIXEL BLACK LINE ON THE LOWER AND RIGHT SIDE
of EACH of the sections, so remember to "eliminate"" THIS
otherwise TOTALLY COOL extremely helpful, bailed me out of a jamb
vizwhiz is offline
Old April 21st, 2005   #3 (permalink)
Tim Nelson's Avatar
Here, check this out. Supposedly you can render small sizes & this will do a good job at super-sizing them. http://www.lizardtech.com/products/gf/
I've used it once in demo, but didn't really take the time to compare it to regular photoshop re-sizing.
Tim Nelson
timnelson3d.com
Tim Nelson is offline
Old April 21st, 2005   #4 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
maybe tweak shadow maps and such so less memory is used, ...or, have you tried cranking up the virtual memory, even though it will slow things down overall?
travis schmiesing
crazy homeless guy is offline
Old April 21st, 2005   #5 (permalink)
 Send a message via ICQ to MrCAD
I think you should also try this app. Originally known as Shortcut S-Spline
http://www.trulyphotomagic.com/short...rie_info&cat=3
Best Regards,
Meher
www.drapefx.com
MrCAD is offline
Old April 22nd, 2005   #6 (permalink)
3dp
Name: david pinnington
Bahrain
my vote goes with s-spline
usedthis several times to go from 72 to 300 dpi in one hit
much better than the p-shop interpolations for resize imho
for me it's mainly clients wanting a image on a site signboard so for this type of work it's no hassle to take a a3 image 2480x1753 and blow it up to 3 x 2 metres
can i have everything louder than everything else please
3dp is offline
Old April 22nd, 2005   #7 (permalink)
Use Genuine Fractals from Lizardtech http://www.lizardtech.com/products/gf/
It is a plugin for photoshop and will handle any image over 1000x500 pixels in size. We use it all the time and it works a treat.
LukaDM is offline
Old April 22nd, 2005   #8 (permalink)
Best Regards,
Meher
www.drapefx.com
I second that suggestion. I have S-Spline and use it on a regular basis. Very customizable (sharpening and antialiasing settings) and works as a plugin for Photoshop, if desired.
Nicholas Moshenko
DesignStor
www.designstor.com
moshenko is offline
Old April 22nd, 2005   #9 (permalink)
great....thanks for all the rapid responses! I think I'm going to give the s-spline a try. It sounds like something that could really help out for this and future projects.
VCRUPI is offline
Old April 22nd, 2005   #10 (permalink)
WOW....that software is AMAZING!! I am completely blown away!
PhotoZoom Pro (formerly s-spline) RULES!
Thanks guys!
VCRUPI is offline
Please Read This Before Posting Images Rick Eloy Finished Work 31 March 15th, 2008 08:20 AM
Please Read This Before Posting Images Rick Eloy Work in Progress (WIP) 3 August 28th, 2007 04:31 PM
Good resource for sky images? Telemachus Autodesk VIZ 4 March 14th, 2005 09:24 AM
Linking to thumbnail images Jeff Mottle Comments and Feedback 7 March 16th, 2004 03:08 PM
