Name: Deri Jones |
Hi folks
Attached is a WIP of a new building - textured in Maya, rendered in Mental Ray with a HDRI dome and one simple area light for sun - Final Gather (800 rays) setting only (no GI). I keep getting these random black splodges - I can't see any connection with geometry. The FG previz doesn't appear to have any holes - only when it's doing it's final run do the holes appear. Anybody got any ideas why this is happening or how to solve it? Thanks Deri (tearing his hair out!) |
Name: Jan-Ruben Fischer |
It could be a material problem. i have these problems in max using the raytrace material, sometimes even with the standard material. i solved it using the DGS-Material even for plain diffuse materials...
Name: Deri Jones |
Thanks - I'll try that. I'm using Photoshop texture file nodes for convenience (does MAX have that? - colour, bump etc on different layers - very handy!) and I wonder if that might be a cause - I rendered the second example again later and it came through without a problem.....
Thanks again Deri |
Name: Mohamed Berry |
Hey... i had the exact problem and it turned out to be caused by wrong saved GI values, so all you'll have to do is to restart & regenerate your GI
some say its the material that causes the prob, for some its the render settings, as for me, i say its the mesh...try to convert everything into an editable poly, let's see. it happened to me, i tried everything, but turning it into a poly worked for me.
WIP... |
WOW!!! That's extreme LOL
Up the sampling, and make the sampling area smaller. I'd check the Hdri for very dark areas and the area light settings-as those maybe 'sampled' to low also. I've never seen mental ray, without GI photons produce anything so dark and well defined. WDA
| mental ray vs. vray | gdamaso88 | Other 3rd Party Renderers | 24 | August 7th, 2006 04:53 PM |
| Mental Ray rendering - black pixels | derijones | Other 3rd Party Renderers | 10 | January 13th, 2006 11:07 AM |
| Colours | Dibbers | Off Topic | 12 | March 11th, 2005 09:00 AM |
| Black marks in Mental Ray Interior | whitewash | 3ds Max | 9 | February 15th, 2005 04:39 PM |
