Old May 24th, 2005   #1 (permalink)
Aaron2004's Avatar
Name: Aaron Nordstrom
Default Best X-Card/Billboard trees?
Hey all,
I'm looking to buy some x-card trees, bushes and plants. I don't necessarily want them for free...I know that good quality and quantity will cost some money, but is there anybody who has had good expereince with buying from a certain site, or is there a good site with cheap/free (yet quality) trees?
I couldn't find any other threads on this here...I searched for x-card and billboard...I can't think of other names you would use for this...so If this thread is beating a dead horse, I'm sorry.
Thanks!
Aaron
Aaron2004 is offline
Old May 24th, 2005   #2 (permalink)
Aaron2004's Avatar
Default Re: Best X-Card/Billboard trees?
I guess to add to my question, does anybody have any experience with Marlin Studios? Do you feel that they charge pretty competitively?
Aaron
Old May 24th, 2005   #3 (permalink)
Maxer's Avatar
If you looking for an all around good low poly 3d tree try Archvisions RPC trees.
Maxer is offline
Old May 24th, 2005   #4 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
search for tree textures or tree images. the x-card trees are just crossing planes. there is nothing special about them besides that. you can create one in about 20 seconds. other than that they just have tree images mapped to them.
http://www.imagecels.com/thumnail/113/113.html
travis schmiesing
Old May 24th, 2005   #5 (permalink)
Aaron2004's Avatar
Is RPC faster and more efficient than 2D boards?
Old May 24th, 2005   #6 (permalink)
Maxer's Avatar
That's what they are basically, there is not an actual model only a place holder. When you’re doing an animation the computer will substitute an image of a tree or bush depending on where your camera is. These trees can be viewed in 360 degrees and even to an extent from the top. So as you rotate around them you able to see the different sides of the tree. If you have Max 6 or 7 you get a free RPC plugin with some sample RPC's, it may be worth it to you to check them out.
Maxer is offline
Old May 24th, 2005   #7 (permalink)
GI Dude's Avatar
Mexico
RPC's are very good and fast, yau can do eye catching renderings with them... the trick is that they are not hi-res, you need to tweak them in PS and above everything else, tey mess allways your GI solution
My advice...
Need a fast and reliable source for 3d entourage, use RPC's
Need cars? cheap? easy to use, for Parking lot? Use RPC's
you can use hi-res 3d models in the foreground also and make a combo of both 2d and 3d objects...
Alex Guzman
GI Dude is offline
Old May 25th, 2005   #8 (permalink)
Aaron2004's Avatar
Thanks for the advice about the RPC things. My problem is that I may want to put this in a real time environment later on, and I'm sure that billboards work, but I don't think RPC will work. You need a plug in, I take it...plus calculation in real time will take quite a lot of power for RPC it seems....
I haven't seen the two compared...is RPC much better than tree textures?
Thanks!
Aaron
Old May 25th, 2005   #9 (permalink)
Bugga_Guy's Avatar
Just a warning with RPC's. If you use alot, the more problems you get. My limit is about 50 before bad things start to happen - even when I click billboard feature.
Bugga_Guy is offline
Old May 25th, 2005   #10 (permalink)
Maxer's Avatar
Actually RPC's use less processing power to calculate than a model would because all they are just different billboards propped up in front of the camera. There is even an option in the plugin to use billboards exclusively so this might be the answer your looking for.
Maxer is offline
Trying out plant plugins Gnarly Cranium 3D Tree & Plant Software and Anything Vegetation 26 September 8th, 2006 09:51 AM
3d TREES Bugga_Guy Autodesk VIZ 31 March 8th, 2005 11:54 AM
Trees in lightscape tercoplo Lightscape 9 July 5th, 2004 04:45 AM
Plz help ! (trees problem) NeckoFromSarajevo Lightscape 2 May 20th, 2004 04:12 AM
Problems with trees Gonzalo Autodesk VIZ 2 June 9th, 2002 04:29 AM
