Old May 31st, 2005   #1 (permalink)
dexter's Avatar
Philippines
Unhappy How to make realistic fabric material in 3ds max?
Hello Guys,
This is my first ever post. Can anybody help me how to create realistic fabric? I want to use them for my blankets, towels, pillows and etc...pls help me.
Any tutorials u can give me?
Do I need a plug-in to do the job?
Thanks...
Dexter
dexter is offline
Old May 31st, 2005   #2 (permalink)
Name: Patrick Macdonald
Default Re: How to make realistic fabric material?
For a basic fabric material, you need a fabric texture map for diffuse and bump. For the diffuse channel, use a perp-falloff map with the fabric bitmap in both slots, but with the 'side' version lightened.
The basic property of cloth is that it lightens as it curves away from you, so the falloff map should do the trick.
hope that makes sense!
madmac3d is offline
Old May 31st, 2005   #3 (permalink)
IC
IC's Avatar
Scotland
Besides the texture, good fabric needs lots of polygons so that you can add surface ripples and bumps. Bump maps never look convincing (imo).
Possibly the best way is using Subdivision Surfaces. When you push/pull an area, the surrounding area reacts, much like in cloth.
You can also use cloth simulation plug-ins but the results are difficult to control.
http://iainc.carbonmade.com/
IC is offline
Old May 31st, 2005   #4 (permalink)
Lebanon
those are very useful insights indeed....I like the material comment very much.
thanks,
Ihab
ihabkal is offline
Old June 1st, 2005   #5 (permalink)
dexter's Avatar
Philippines
Smile Re: How to make realistic fabric material?
Thank you Patrick & Iain, I will do as what you adviced...
Thanks alot guys...
dexter is offline
Old June 1st, 2005   #6 (permalink)
Great points Patrick, I learn a little with the basics given today, Thanks
rafael_l is offline
Old August 29th, 2005   #7 (permalink)
Name: Sjoerd Olislagers
Netherlands
Hi Guys a First timer here too.
Im currently using Fprime for interiors and i also have trouble creating a convincing fabric material. Can some one like explain a bit better???
Also i wonder how you guys make a simple wall material. Im wondering cuz i use a really basic, non-bump-map material. Make it a warm-white and tweak the diffuse, but thats it really. How do you guys make a wall material?
Thx
novocain is offline
Old August 29th, 2005   #8 (permalink)
IC
IC's Avatar
Scotland
For plaster finish walls I generally use an 80-85% diffuse material with a subtle Turbulence procedural in the colour channel set to a slightly cooler shade than the main colour. The Turbulence is 10mm, 20mm and 15mm in scale at around 25% opacity.
I copy that and paste it into the bump channel and set the specularity to 8% and reflection to 2%.
You need some variation to cast subtle shadows.
This is how it turns out..............
IC is offline
Old September 12th, 2005   #9 (permalink)
Netherlands
Ill give it al go. Thx alot
novocain is offline
Chrome material problem evanmoses VRay Render 18 March 16th, 2005 09:12 AM
Can't make material white enough! JPS Autodesk VIZ 7 March 24th, 2003 01:53 AM
How to make a belivable street pave material? archkre 3ds Max 0 November 17th, 2002 09:59 AM
Material Script nisus Scripts 5 July 8th, 2002 11:49 PM
