Name: herbert mellville |
Just replaced motherboard and processor (amd atlon 64 3500). Re-formatted and installed XP Pro. After install, upon boot, i get a "Hal.dll corrupt or not found" error. Anybody have experience with this? I've tried a numberof things, including installing sp2 wich replaces the existing hal.dll file. hal.dll is in system directory, but still - error occurs. windows will not start normally unless i have the cd in. if i put the cd in, i don't get the error and boot normally although i cant install many programs. help appreciated.
thanks |
Name: Richard McCarthy |
Try this :
http://www.kellys-korner-xp.com/xp_haldll_missing.htm and this : http://support.microsoft.com/default...b;en-us;330184
Don't mess with my hat !! |
I have already tried all these. no go. could it possibly be some sort of hardware issue? this is a fresh install of win xp pro, reformatted hard drive. have reinstalled multiple times... could be cd has scratch? im going nuts.
Name: J Halton |
''I dont want to talk about it Ernest. I think you are been irrational Ernest. What seems to be the problem ernest....Daisy Daisy give me your answer do........'' heh heh heh
Just ask. You never know! |
Name: Robin Hoover |
Hardware Abstraction Layer.
this i know from the following act of gracelessness: was using the end of the vacuum to suck the dust and crap out the inside of the comp and accidently knocked the r.a.i.d. connection from the hdd off its mb prongs (so gently that i didn't even notice). as i learned, during the p.o.s.t. the bios first checks the status of the hardware attached to the motherboard, then segues into the software, which kinda makes sense. short story, make sure everything is well attached |
thanks for the help, or should i say humor. im just glad to see a couple of people had some fun at my expense while beeds of sweat poured from my forhead onto my motherboard. I didn't spend the time to configure my bios. Had a PCI sound card installed with onboard sound card set to on, BIOS was looking to slave hard drive for motherboard, and SATA was on (while i have no SATA drives). after making these changes in the bios, xp installed fine.
