Name: eduardo castillo |
My interiors in vray tend to be on the slow side....
Especially if i have the knick knacks like Blury refs, displacement, refractions, fresnel refs,vray lights,area shadows,hdri, etc... In exteriors, vray cuts trhough renders like butter, but the interiors take about 4, 5, 6 hours or more to get a decent resolution. Is this normal? How can i seepd up interiors? lightscape used to take no more than one hour for the same kind of images, but is way too obsolete now.. |
Name: Andrius Stankus |
If I can bring it down to 1 hour per frame, I'm happy. There are things you can do to speed it up without killing the quality. Though I have a small render farm, without that I would be toast.
Name: Sawyer Fischer |
I am working on one image and its 4 hours. I have a lot of stainless and I have glossy reflections on them. What I have works but I may try to work backwards to lower the settings till they look bad. I never know if the settings I have are too high and could be optimized.
Name: John Dollus |
Well, if you run a low resolution prepass, save out the IR map and then run a full pass along with a seperate pass with no GI - only complete specularity for a reflection pass, you can keep frame times down.
well, I guess the question that really needs asking is: "is this an animation or still???" For a high rez still 4,5 or 6 hours isn't too bad. I've had some stills render for 40 hours, of course they are like 10,000 pixels wide and such... For an animation I always render out the irradiance map first. Saves a TON of time.
#7 (permalink) | |
Name: Daniel Kreimer |
'Back in the young fatherland' |
| Vray - Proxy objects and Distrubted Rendering? | JamesTaylor | VRay Render | 18 | 1 Week Ago 12:25 PM |
| Test your PC rendering speed with Vray!!! | kris | Hardware and Technical Discusions | 14 | April 27th, 2007 10:28 AM |
| vray lighting / rendering issue | mike_sul | General Discussions | 3 | December 14th, 2004 06:01 AM |
| First Time Night Rendering | Diver | Finished Work | 1 | December 13th, 2004 10:10 PM |
| Massive rendering time....am I doing something wrong | Apropos | General Discussions | 15 | October 1st, 2004 08:26 AM |
