Old October 19th, 2005   #1 (permalink)
Ian P's Avatar
Default accurate landscaping??
Hi,
I was wondering if anyone knows how use the height data from a site survey in autocad, to create an accurate lanscape mesh in max with correct relative heights, can this even be done? does it need to be done in autocad then exported? i really have no one else to learn from here and am pretty stuck any help gratefully recieved. thanks.
Ian
Ian P is offline
Old October 19th, 2005   #2 (permalink)
Default Re: accurate landscaping??
yes it can be done.
1st draw your contour lines in CAD and place at their respective heights. Import into max or viz and use the terrain tool to create a mesh in accordance with the contours.
i suggest the best thing would be check out the help files in max - search for terrain
James
JamesTaylor is offline
landscaping in marketing Aaron2004 General Discussions 4 May 27th, 2005 07:54 AM
Accurate Materials take-off software? keithg General Discussions 3 December 9th, 2004 08:46 AM
Accurate Interiors/Glass Gander0 General Discussions 6 June 4th, 2004 03:09 AM
How accurate is Viz/Max IES Lighting? Bishop General Discussions 17 February 19th, 2004 04:43 AM
can C4D use accurate light intensities? jackb602 Cinema 4D 3 February 13th, 2003 05:37 AM
