Old December 29th, 2005   #1 (permalink)
Default Mesh Displacement Tool
Dear Group,
I need to ask if anyone knows of any modeling software or plugin to Max/Viz that can displace a mesh (not to be confused with MTD, which is performed during rendering) progressively. I use VIZ and I am familiar with it Displace modifier. Although it is somewhat useful, the mesh needs a lot of definition (i.e. a lot of triangles) for it to operate properly. What I would like is a tool that can displace a mesh (using the UV coordinates and a bitmap) progressively by automatically subdividing the mesh in areas where necessary as directed by a user defined resolution parameter. The reason why I seek this is because the rendering software that I use doesn't support displacement mapping. Although displacement mapping is not the most important thing in the world to me, there are times when I would like to slightly displace the mesh just to add a little depth thereby enhancing the overall realism. An example of this would be a chimney fabricated with cultured stone. An image mapped onto a box has a fake look to it. My idea is to slightly displace the mesh and combine it with a normal map to bring out a more natural appearance.
Marcus
marcdevon is offline
Old December 29th, 2005   #2 (permalink)
wda
wda's Avatar
Name: William Alexander
Default Re: Mesh Displacement Tool
Max proper has the ability to animiate through the subdivision surface of a polygon mesh. Viz has limitied abilities in that area.
You could use a proxy approach, display and hide the appropriate subdivided mesh based on the level of detial needed. Visibility is animatable in Viz. Low subdivision geometry, med and high. Setting each one to display for a period of time while the others are not.
WDA
wda is offline
Old December 29th, 2005   #3 (permalink)
Timothy Saunders's Avatar
how important is it? enough to justify purchasing vray? vray's displacement modifier is so easy and works so good. you get great results, and the adjustments available are so nice. works great for stone, among thousands of other stuff. youcan specify your resolution, the depth of the displacement effect. you can use the texmap from the objects material, or have a map completely different from the one assigned to the object.
Timothy Saunders is offline
Kinda dumb mesh question AJLynn Cinema 4D 6 November 3rd, 2005 05:57 PM
creating mesh material frank1331 3ds Max 1 July 25th, 2005 02:38 PM
Vray displacement problem Dan J VRay Render 1 July 24th, 2005 02:25 AM
MAX6 MR Displacement Shader wda 3ds Max 1 April 7th, 2004 09:46 AM
