Name: Jonathan Sanchez |
What do you guys use to make recessed ceiling lights. I was thinking about boolean them in the ceiling but I was wondering if there was an easier way. I've noticed some of you just place a cylinder in roof and photoshop it later, but sometimes they come out looking like dots in the roof.
Skylight? |
Name: Stephen Leworthy |
depends what the recessed lights look like. it's obviously better to 'place' the lights on the ceiling and do it that way, but if they must be recessed then yes, you must recess them.
usually by either modelling the cieling with the holes in it in the first place, or maybe (if your using max/viz) use the shape merge command instead of boolean. much fast, smoother and reliable for this type of thing. |
Name: Jan-Ruben Fischer |
I normally use a cylinder which has a light-texturemap on the cap. The cylinder sticks out a little bit. So I can reposition them or hide them if I like. That works best if the recessed lights are even with the ceiling and not rendered as close-ups. lighing either with glow-glare shaders or just photoshop.
If you keep your ceiling plane as a spline object with a normal modifier on top (this turns it to a face, and usually to draw your ceiling in plan so you need to flip the face normals), then you can have circles in the spline for your recessed light locations. That'll cut the holes for you -- it's cleaner than a boolean, and you can always go back to the spline object and reposition the circles if the lights need to be moved.
I'm not sure I understand JR's suggestion, but can lights and such will usually have a lip or something that is slightly below the ceiling -- but the bulk is always sunk into the ceiling. You need to cut holes in the ceiling plane for this to actually look right. Shaun |
Well here is how the results came out. I used Strats suggestion about shapemerge and worked wonderfully. Thanks Strat. Here's the link:
http://www.cgarchitect.com/vb/14034-interior-family-room.html
Skylight? |
| Texture Lights in Radiosity? | MegaPixel | 3ds Max | 5 | August 25th, 2005 02:46 PM |
| photometric lights | kamikaze | 3ds Max | 8 | July 17th, 2005 10:21 PM |
| multiple fluorescent lights... | chuck | Autodesk VIZ | 2 | June 3rd, 2005 02:20 PM |
| setting good light levels for lights vs. sunlight | Ernest Burden | Cinema 4D | 39 | May 22nd, 2005 11:04 PM |
| MR and photometric lights? | 723D | 3ds Max | 2 | January 24th, 2004 04:02 PM |
