Old May 17th, 2006   #1 (permalink)
Default using an object as a light source
Hello all,
how can i use a rectangular object as my light source for an interior scene? say i want a rectangular glowing table lamp. instead of putting an omni light inside the object, i want the actual object to light up the scene. please help .
Alan
AlnIS300 is offline
Old May 17th, 2006   #2 (permalink)
Rick Eloy's Avatar
Default Re: using an object as a light source
Only when you use radiosity. You can create, let's say, a plane and assign an Architectural material to it. Put the desired value for its illuminance and, under the Advanced Lighting Override tab, check "Emit energy".
Rick Eloy
Rick Eloy is offline
Old May 18th, 2006   #3 (permalink)
tanni's Avatar
Bangladesh  Send a message via MSN to tanni Send a message via Yahoo to tanni
Vray have also that sort of option, You can try.
tanni is offline
Old May 18th, 2006   #4 (permalink)
nisus's Avatar
Name: Evert Vandenberghe
Belgium
What renderer do you use?
nisus
nisus is offline
Old May 18th, 2006   #5 (permalink)
i'm using Brazil R/S. please help. thanks.
Alan
AlnIS300 is offline
Old May 18th, 2006   #6 (permalink)
nisus's Avatar
Belgium
Can't help you with Brazil, ask Quizzy.
nisus
nisus is offline
Old May 18th, 2006   #7 (permalink)
Rick Eloy's Avatar
Doesn't Brazil have a light material?
Rick Eloy
Old May 19th, 2006   #8 (permalink)
tanni's Avatar
Smile Re: using an object as a light source
nisus
there have an option under General light option -renderable you may try.
tanni
tanni is offline
Old May 19th, 2006   #9 (permalink)
quizzy's Avatar
yep, just check the "renderable" in the light modify panel... but you can ofcourse also put planes in the place of the lights to get more control over the reflections.
basically what you do is:
-create an area light
-create a plane with the same dimensions of your area light
-on that plane put a white standard material with self illum at 100 and an output map in the diffuse channel and tweak the RGB value. try it on 8 and render.
-if you have lots of reflective/refractive glossy/non-glossy materials in your scene you get those really nice speculars on your objects..
see attachment for result you can clearly see those nice planes reflecting in the cupboard. this is only possible if you set your output higher as the standard 1...
Michiel Quist
http://www.3idee.nl
quizzy is offline
Old May 22nd, 2006   #10 (permalink)
Hi,
now i know this is Brazil specific but something i found that can work also it to make a geometry apply a Finalrender advanced material to it and then you can ramp up the GI Send of the object and with self illumination on you can get the object to make light.
I have done this to create soffit lighting etc.
I havn't used Brazil in a long time and as such am not sure if you can do the same thing... its more the principle i was trying to illustrate.
Hope you get it sorted man
soulctrla is offline
Seeing the light source Carrotious 3ds Max 0 April 9th, 2005 05:57 AM
Light passes through object with Menatl Ray Teratron 3ds Max 6 April 5th, 2005 03:37 PM
light source evanmister 3ds Max 8 December 1st, 2004 12:48 PM
luminaire-block with more than one light source rpict Lightscape 4 August 6th, 2004 07:49 AM
Light emitter object TAKA Autodesk VIZ 2 August 11th, 2002 01:06 PM
