I'm a complete n00b at Brazil, never touched it before yesterday, but my firm owns it (there was a 3D guy here who bought it 4.5 ago and left 2 ago) and I'd like to see if I can figure it out before I go and buy Vray. I've been working with a model of my current architecture project that was done by a consultant. Are there still any Brazil people here who I can bug with questions?
I've got the latest 1.2 release on Max8, my model is one big editable poly, my materials are standard except some windows that are off-the-shelf Brazil glass. I've used a Brazil direct light with a giant radius for the sun and given it a smaller photon focus to hit the building and immediate surroundings. I'm using Mitch-Net at -1/3, global photon with 300000 photons from the sun and the rest of those settings at default, QMC at -3/0, sky light in direct and indirect with a slight blue. First problem (there will be more): in the attached renders, I've got concrete block and brick materials that use the Tile map. The brick has color and bump maps, the block is gray with a bump map. In the parts that receive direct light, the bump works fine, but where it's in shadow it's relying on QMC to do the bump map and it gets these artifacts (I did some diagnostic renders showing GI samples and the artifacts happen where the samples aren't). I can kill the artifacts by bringing min rate up to 0 but that kills the render time. Is there a better way? |
Can you post your Luma Server settings for me? I used Brazil for a long time (although not recently) and I may be able to assist. Did you try posting on the Brazil forum?
Edit: Actually, you could probably try increasing your View Rate from the default (15) to something like 25 and see if that makes a difference (I think it should). If that doesn't help, post the settings and I would be happy to take a closer look. Last edited by moshenko; September 14th, 2006 at 02:12 PM. |
The View Rate seems to be working, thank you.
Next question According to the entry on Regathering in the Brazil customers tutorial area, you get regather by turning on global photon and setting the Luma Server's bounces to 2. (The only place with Bounces control is the Sampling Control.) When I do this it just seems to darken the scene. Is there another step? First image has Bounces=1, second has Bounces=2 |
#4 (permalink) | |
When I was using Brazil regularly I rarely used photons for exterior scenes for these same reasons. I found that they lead to more errors than just a plain QMC scene and that I spent much of my time trouble-shooting the photon settings. Straight QMC in Brazil can be pretty quick for exteriors so you may want to experiment with that. For an interior scene, regathered photons are the way to go, IMO. Hope this helps - |
You're right, I should have caught that - mental ray would have given me the same problem, and I'd solve it with multi-bounce Final Gather instead of photons. Here, the photons must be bouncing into space, doing almost nothing productive but messing me up with sampling radius.
Name: Justin Hunt |
I'd second the non use of Photons for exteriors.
These are some general settings that I use for exteriors : JHV If you turn on Indirect Illumination, then be sure not to have the sky light do secondary bounces, only point, omni and area. An other trick with skylight without indirect is to turn shadow casting Off for your ground. Its not physically correct but does allow for more light onto the sofits and deep recesses. Last edited by Justin Hunt; September 14th, 2006 at 04:43 PM. |
Name: Justin Hunt |
They may seem like alot of controls, but in reality Brazil is very easy. I find that Brazil has one of the best image sampling quality.
Have fun JHV |
Name: Justin Hunt |
what is it about Vray users,
This is clearly a thread for Brazil. If you dont have anything to contribute that is Brazil related please keep your thoughts and comments to yourself. By the way I am a Vray user as well. JHV |
| Brazil render help | yogeshwagh | Other 3rd Party Renderers | 5 | June 20th, 2006 04:48 AM |
| Configuring Brazil Rio in Viz 4 | Fcespedes | Other 3rd Party Renderers | 1 | July 19th, 2005 01:20 AM |
| Brazil for Rhino at Siggraph | Nick Nakadate | Other 3rd Party Renderers | 0 | July 24th, 2004 01:25 PM |
| brazil reflections | colorID | Other 3rd Party Renderers | 1 | April 15th, 2004 09:31 PM |
| Exterior street scene - Brazil renderer | mhinks | Other 3rd Party Renderers | 3 | April 8th, 2004 10:09 AM |
