Old September 25th, 2006   #1 (permalink)
andreg's Avatar
Canada  Send a message via MSN to andreg
Default Need help making window scrims
Hi guys,
I need help making window scrims for a showroom that I am making. How would you guys go about creating those scrims that are semi transparent from the inside and opaque from the outside? From the outside view, we would see the printed graphics on those scrims through the windows and from the inside we would see outside. By the way, I'm using V-ray (1.5)
andreg is offline
Old September 25th, 2006   #2 (permalink)
STRAT's Avatar
Wales
Default Re: Need help making window scrims
is this for an animation? (where you see both sides of the same scrim in the same sequence)?
STRAT is offline
Old September 25th, 2006   #3 (permalink)
andreg's Avatar
no animation, stills only
thanks for the quick reply
andreg is offline
Old September 25th, 2006   #4 (permalink)
BrianKitts's Avatar
if you are just doing stills I would highly recommend setting up seperate scenes. You will get faster rendering times and have an easier model to navigate if you aren't loading everything into one scene.
Create your building shell place it in two scenes, and then in one model detail the interior, and in another detail the exterior. This of course will create two seperate scrims that you can apply different materials to, making for the desired appearance in each scene.
Brian Kitts
ANSHEN + ALLEN
BrianKitts is offline
Old September 25th, 2006   #5 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
Originally Posted by andreg
Hi guys,
Vray2SidedMtl would work for this if your glass material were a plane instead of having a thickness.
travis schmiesing
crazy homeless guy is offline
Old September 25th, 2006   #6 (permalink)
andreg's Avatar
Good idea I never thought of using 2sided vray mat, thanks
andreg is offline
Arch. Desktop: double hung window in a curved wall?! Aspiring Visualizer! AutoCAD/AutoCAD Architecture 2 May 1st, 2008 07:18 PM
Door/ Window Assembly Clean-Up JMBknvc AutoCAD/AutoCAD Architecture 0 August 10th, 2006 04:59 PM
window glass problem roland Work in Progress (WIP) 5 January 2nd, 2006 04:00 AM
window animation, noob help Pumuckle General Discussions 2 July 1st, 2004 06:17 PM
Reflection in glass window magnifying lmorales Lightscape 1 October 8th, 2003 02:28 AM
