Old October 6th, 2006   #1 (permalink)
Default radiosity units in VIZ2006
Hi there!
I'm having a problem with an AutoCAD 3D model which units are set like 1 unit= 1 mm, resulting in a model where 1 meter is 1000 units. When I import the file to VIZ 2006 and proceed with the radiosity solution, I can see the radiosity solution in the viewport, but when I do the render, the radiosity solution looks like a normal render. Can anyone tell me why this happen? I tried to scale the model to 1 unit= 1 meter but when I import it to VIZ it looks messy, with a lot of breaks.
P.S.: This only happens to me with the models where 1 unit = 1 mm.
arqs is offline
Radiosity rant (3D Fluff) Wokka Cinema 4D 12 February 1st, 2005 01:37 AM
Radiosity (doubts!) doujay888 Work in Progress (WIP) 3 December 6th, 2004 08:30 AM
SImple Radiosity Scene Setup MegaPixel 3ds Max 8 July 29th, 2003 08:17 AM
How to turn off Radiosity??? Aaron Autodesk VIZ 3 July 28th, 2003 12:34 PM
Further explanation using radiosity G Autodesk VIZ 4 May 12th, 2003 04:37 PM
