Old October 13th, 2006   #1 (permalink)
Woody's Avatar
Default Help with patches over large walls.
Hi Guys,
Sorry if this has already been covered but I did search and couldn’t find anything.
As you’ll see from the small previews I am getting splodges over my walls, can someone tell me if my settings are too low and if so what they’d recommend? (I am still on Vray 1.49)
I’ve used the noise threshold in the past to try and remove this problem but since the default changed I’ve no idea what’s a sensible number to set it at? Plus I can’t remember if it is the “Adaptive Subdivision Images Sampler” or the “Vray QMC Sampler” that I should be changing?
Thanks!
Woody is offline
Old October 13th, 2006   #2 (permalink)
Tommy L's Avatar
Default Re: Help with patches over large walls.
Hello woody, hows it going?
You could try lowering the interp. samples. This blends the shadow samples more. Try it on 15 and see what that does. You will have to re-calculate the irr map (looks like youre rendering from a saved file). Dont know about the light cache (i take it thats second bounce) because it has different parameters in 1.46.15 which im using.
Have you noticed much improvement between 1.46 and 1.49?
Tommy L is offline
Old October 13th, 2006   #3 (permalink)
Woody's Avatar
Cheers Tom, i'll give it a go!
I am good mate just plodding along, thinking of moving to London at the begining of next year. Hope you're ok mate?
Any more advice welcome.
Woody is offline
Old October 16th, 2006   #4 (permalink)
Tommy L's Avatar
yes im ok, back in chicago after 3 months in UK sorting my visa out. Its a rockin city, if you ever feel like getting out of england i know a couple of guys in the business out here that may be able to fix you up.
Tommy L is offline
Old October 30th, 2006   #5 (permalink)
Woody's Avatar
Does anyone else know what could be causing the patchyness???
Woody is offline
Walls & Dims Sawyer Autodesk Revit 12 March 24th, 2006 10:05 PM
Animating walls coming out the ground aflack 3ds Max 4 August 4th, 2005 04:57 PM
Large Marina Scene setup/Usefull tips? mhinks 3ds Max 6 June 9th, 2004 06:11 AM
crazy walls? attaching emselves anywhere..... kingeldar AutoCAD/AutoCAD Architecture 17 April 26th, 2004 10:07 AM
rendering large scenes, very large scenes guyhaviv 3ds Max 3 September 30th, 2003 02:46 AM
