Name: Mark Woodard |
I'd recommend a programme called Terragen, you can produce some very pleasing results very quickly.
The company offer a free download but restrict you on the render output size. Still,, buying the product is pretty inexpensive. PS: I don't work for them. |
Name: Tom Livings |
for animation or stills?
Name: Iain Collins |
Using a digital camera.
http://iainc.carbonmade.com/ |
there is a great resource right on cgarchitect.com! a series of fantastic artciles/ tutorials by Brian Smith, http://www.cgarchitect.com/upclose/VI/default.asp
scroll down, you will see one titled "a little background information" enjoy! |
Name: Tom Livings |
For stills you can use any photo you like. If you have access to the site, go take a picture. If is an imaginary project, find something on google, scan in a photo, do whatever. The most 8important thing is to have a clear image in your mind of what you want to acheive. It sounds like you want to learn but dont know what to do. Just follow some tutorials first.
Not necessarily what you're after, but I just wanted to share this idea that I used on a recent project. For a location-specific background for an animation I used Google Earth.
1. Zoom in on your location and tilt down to almost ground level. Turn on terrain. 2. Navigate to the centre of your site and starting facing north take a series of 16 images rotating round another point of the compass each time. 3. In Photoshop crop the images width by 50% to reduce the amount of overlap, then use photomerge to stitch them together. 4. Scale up the image and apply a slight blur to reduce pixelation. 5. Use the magic wand to select and delete the default blue sky colour and bring in a panoramic sky of your own on a separate layer. 6. Offset the sky layer to align the sun part of the sky with south on your landscape. Merge together and save. 7. Map onto a cylindrical plane around your site model, again aligning south on your map with south on the model. That's it! A wee bit laborious I know but worth it depending on the context. Here are a couple of images from the animation I used this on. frame 787.jpg frame 1215.jpg Last edited by stef.thomas; February 2nd, 2007 at 07:35 AM. |
| Hot fashion models - HELP!! | smorehouse | 3ds Max | 10 | June 14th, 2006 07:20 AM |
| models causing max to crash | carlangas | 3ds Max | 4 | August 10th, 2005 04:39 PM |
| 3D Models under new cgarchitect shop? | Jorbu | General Discussions | 1 | July 28th, 2005 03:22 AM |
| Aston Martin 3d Models | juxtm | General Discussions | 3 | February 19th, 2005 04:46 PM |
| Furniture models for CGA | thnieves | Off Topic | 7 | February 17th, 2005 03:34 PM |
