Autodesk VIZ Autodesk VIZ
Old March 29th, 2007   #1 (permalink)
archkre's Avatar
Argentina
Default What version of Vray will work over Autodesk Viz 2007 if any?
Thanxx
'Back in the young fatherland'
archkre is offline
Old March 29th, 2007   #2 (permalink)
alias_marks's Avatar
Default Re: What version of Vray will work over Autodesk Viz 2007 if any?
You should be just fine with the latest release. I've been using RC3 with viz2007 since it came out and have had no compatibility problems at all.
www.DownTownMikeBrown.com
alias_marks is offline
Old March 29th, 2007   #3 (permalink)
I believe it's just about any version except 1.47. Just like alias_marks, I use VIZ 2007 with Vray 1.5 and everything works great.
jophus14 is offline
VRay X RPC: does it work? Rick Eloy VRay Render 5 April 18th, 2007 05:36 PM
Ten vray questions steve VRay Render 9 September 15th, 2004 04:42 AM
about Vray versions and VIZ 4.2 salf VRay Render 8 March 2nd, 2004 02:47 AM
a bit different approach.... choochee Finished Work 5 February 16th, 2004 12:37 AM
URGENT!!I can't get transparencies to work in powerpoint 2k2 (xp version) schmoron13 Off Topic 0 October 31st, 2003 07:38 AM
