Autodesk VIZ Autodesk VIZ
Old April 9th, 2007   #1 (permalink)
Saturn's Avatar
Default Viz Issue
Hey everyone. I have been having issues with Viz2007 crashing my computer. It doesn't happen every time I use it just sometimes. There is nothing I am doing specifically to make it crash. I am using Vray too. It happens at work and at home. Has anyone else had this problem.
Thanks,
Jason Matthews
Saturn is offline
Old April 9th, 2007   #2 (permalink)
alias_marks's Avatar
Default Re: Viz Issue
I've had this un-explained crash before. Usually I've found it has something to do with the video card and the way Viz is trying to show a material in the viewport. Sometimes it's an corrupt object. Turn off all materials showing in viewport (toggle that white and blue checker box in the material editor - espically for transparent materials)
I would also try switching form OpenGL to DirectX or visa versa, distill things down and find out what material or object is causing the problem
Could be something completely different too, this is just what I've found can happen sometimes.
good luck
Mike
www.DownTownMikeBrown.com
alias_marks is offline
Old April 9th, 2007   #3 (permalink)
Saturn's Avatar
I shall try this. Thanks Mike.
Jason Matthews
Saturn is offline
3GB Switch Video Card Issue thickly Hardware and Technical Discusions 3 September 10th, 2006 06:34 AM
Archicad & 3d Studio Max materials issue violater Archicad 2 January 24th, 2006 08:30 AM
CAD to MAX issue......snaps problem salf 3ds Max 6 June 9th, 2005 11:43 AM
I think it is a harware issue so please read...Xeon and C4d crash! Andronikos Hardware and Technical Discusions 2 August 19th, 2004 03:17 PM
dual CPU issue Beno Hardware and Technical Discusions 3 April 6th, 2004 06:58 AM
