Name: Anwar Fardullah |
does viz2008 support dual-core xeon? i have a macpro with winxp pro x64, and when i render, it shows 4 cpu but only 2 threads are utilized. the multi-threading box in ticked, and my task manager shows 4 processes
Name: Angelo Marasco |
There was some discussion about this in the past, and from what I remember, VIZ is only 32bit, so unless you buy MAX, you aren't going to get true multi-treaded performance.
However, Mental Ray and Radiosity (or Advanced Lighting) should use all your processors. If you are doing a regular scan-line render, you might not see more than two...
www.ar7.com ________________________________________________ Denver_Modern: Blog, the tale of building a modern home in Denver, CO |
hmm...guess either have to wait for the x64bit version or upgrade to max
did a test render using Mental Ray and it only shows 3 threads. so i guess it is really limited to that since it's 32-bit |
| Distant light not working in acad 2008 | Macpod | AutoCAD/AutoCAD Architecture | 6 | April 3rd, 2007 01:53 AM |
| Bionatics Introduces its EASYnat® Plant Simulator for AutoCAD® 2008 | Jeff Mottle | CGA News | 0 | March 27th, 2007 12:00 AM |
| impending autodesk release info | vizwhiz | Off Topic | 0 | March 5th, 2007 10:57 PM |
| Autocad 2008 | antonio_frias | AutoCAD/AutoCAD Architecture | 15 | February 15th, 2007 01:10 AM |
| Multi mats | Sawyer | 3ds Max | 3 | May 25th, 2005 09:36 PM |
