Autodesk VIZ Autodesk VIZ
Old April 23rd, 2007   #1 (permalink)
Default Slow Rendering Via Backburner...???
If i render my scene by opening the file locally on a machine and hit render i get a render time of between 5 and 10 minutes depending upon which machine i use (inc. calcualting Irr Map)...
However, i have left an animation to render over the weekend, sending it through backburner and using the server etc. on each machine and i'm getting render times ranging from 1hr 15min upto 7hrs?????? This is with having already precalculated Irridance Maps.?
Has anyone else had the issue before, if so what solved it... if not, does anyone have any ideas they'd like to throw into the ring as to why this has happened and how to correct it??
JamesTaylor is offline
Old April 23rd, 2007   #2 (permalink)
Default Re: Slow Rendering Via Backburner...???
Should also note that its backburner 3.0.2
from an initial test it seems to be something to do with using the precalculated irridance map? If i open the file locally and and assign vray to use the precalculated irridance map everything slows down??
Old April 24th, 2007   #3 (permalink)
alfienoakes's Avatar
James,
Do all the machines have access to that IR map file..? Is it loading the map file from a network location to each node..?
Maybe try loading it onto each node separately and see how that works.. Although you say you have tried it locally and it slows it up..
Obviously, if its pre-calced, it should be faster...
Hmm.. Im now just thinking out loud and whaffling......
Andy Wiggins
MAKING COFFEE.
Making a cup of coffee is like making love to a beautiful woman. It's got to be hot. You've got to take your time. You've got to stir... gently and firmly. You've got to grind your beans until they squeak. And then you put in the milk.
Swiss Tony.
alfienoakes is offline
Old April 24th, 2007   #4 (permalink)
Thanks for the thoughts Andy... its looking as if it was caused by a corrupt or broken Irridance map file.
I'm currently re-rendering the map in question and have tested a couple of frames early on... hopefully when its complete everything will be ok again.
I'll post the outcome when i'm happy its working and not tempting fate to much!!
Old April 24th, 2007   #5 (permalink)
Makes sense..
I did think about that afterwards. Couldn't be too many things..
Andy Wiggins
MAKING COFFEE.
Swiss Tony.
Using Backburner with VRay Distributed Rendering? ericbarlow21 General Discussions 3 April 5th, 2007 12:55 PM
NEWS: ARTVPS Launch new Rendering Solution with Mental Images Jeff Mottle SIGGRAPH 2006 0 August 1st, 2006 09:41 PM
slow rendering gvisual2005@yahoo.com.sg VRay Render 5 February 25th, 2006 08:41 PM
vray rendering animation with backburner keeps rendering 1st frame d7man2000 VRay Render 3 February 21st, 2006 01:02 PM
Network Rendering with Backburner Bewdy Hardware and Technical Discusions 5 December 15th, 2004 05:31 AM
