| Autodesk VIZ Autodesk VIZ |
Name: Enrique Sanchez |
Ok, so i am trying to make an animation that looks like you are riding a bike through a path. I have attached a generic target camera to a path, and then also attached a model of a bicycle to the same path. However, once I preview the animation, the bike appears to be very shaky and make these sudden jerky movements as it progresses along the path. Does anyone know why, or how to prevent this??
Thanks in advance.... |
Name: julius hontarigo |
select all your vertices, right-click, choose smooth.
hope that helped.
the early bird gets the worm, but hey, the late worm missed the bird. |
Thank you,
I assume you mean that I should make hte verticis along the path, I have done that and the movement is still quite jerky. Any other suggestions?? |
do you have a lot of vertices close to each other?
No, they are not too close together. I did not have this problem when I initially attached the camera to the path, meaning that the camera moved smoothly through the model.
Name: Eduardo Romero |
try normalizing the spline. other solution is to replace the original spline with a NURBS curve. (they have no vertices so the movement is a lot smoother)
Eduardo
"I have nothing to do with the real world anymore. Please don't insist." Eduardo Romero |
That didn't help either!!! I'm running out of time. I am including the file on this post, perhaps you all can take a look? I would greatly appreciate it!
Thank you. |
Its not a matter of the spline itself. The problem lies in the sampling of the path.
under the motion tab, select the samples spinner, and add more samples. I understand that you have a spline and you have created the motion path from the spline. Before you create path add some more samples - by default its 10 i think, give it 32 and try it out. The samples option does the same thing to the path as the interpolation does to the spline.
Im starting to suspect that the world is a rendering... Last edited by Horhe; May 4th, 2007 at 05:49 PM. |
I should be increasing hte smaples on the path, right? When I tried that, it did not solve the jittering. I also upped the samples on the spline, the bike itself, and the camera, but none of those fixed the shakyness.
any other suggestions? |
| Vray animation render problem | field3d | VRay Render | 4 | January 15th, 2007 11:34 PM |
| camera animation problem | psv1 | 3ds Max | 3 | September 21st, 2006 02:34 PM |
| IRMap animation problem | aligrafix | VRay Render | 18 | June 2nd, 2006 03:19 AM |
| Path Deform Modifier Problem... | Claudio Branch | General Discussions | 0 | February 3rd, 2006 07:33 AM |
| Viz4 Animation Jitter/Flicker Problem | jbennett134 | Autodesk VIZ | 6 | March 25th, 2004 08:39 AM |
