Old May 7th, 2007   #1 (permalink)
New Zealand
Default Emitter renders Black??
For some reason any emitter I render in my scene turns black. Help!!
Why is this happening?
nzjimmy2001 is offline
Old May 8th, 2007   #2 (permalink)
Maxer's Avatar
Default Re: Emitter renders Black??
It could be that the object you applied the emitter to has its normal’s flipped, or the emitter material it's self is turned off or the wattage is very low.
“There is no spoon”
Maxer is offline
Old May 10th, 2007   #3 (permalink)
New Zealand
hmm doesn't seem to be any of those problems. bugger. thanks for the suggestion tho.
Old May 10th, 2007   #4 (permalink)
ClaudeFerret's Avatar
Are you rendering from a plugin, or from Studio?
ClaudeFerret is offline
Old May 10th, 2007   #5 (permalink)
New Zealand
from plugin
Old May 10th, 2007   #6 (permalink)
Apply your emitter to a solid, like a sphere, and see if it still is black. Also, does the emitter thumbnail material show up as black?
Old May 20th, 2007   #7 (permalink)
New Zealand
yes i did try applying it to a plane. yes the preview is white as it should be. i was thinking it may be a scene scale issue?
Old May 22nd, 2007   #8 (permalink)
Well you could crank up the emitters value to a ludicrous level to see if it is illuminating the scene. I have heard of this problem with scenes containing old maxwell information mixed together with current mats.
If changing the values of your emitter does nothing, I would suggest moving it to Studio and trying it there. Apply the default mat to every object in your scene, then create a new emitter in Studio and apply it to your plane. Crank up the level of the emitter and see if you get a result. Double check the normals direction.
This should get a result, if it doesn't, try posting the file and I am sure someone will help take a look at it for you.
If it is Rhino, I would be happy to check it.
Rendering Black at Hi Resolution JamesTaylor VRay Render 2 March 2nd, 2007 02:57 AM
Black walls del82 Lightscape 8 November 6th, 2006 04:20 PM
Please Advise on renders - who should be doing them and what is the timeframe? bob332 General Discussions 13 September 23rd, 2006 09:31 PM
Colours Dibbers Off Topic 12 March 11th, 2005 09:00 AM
Pitch black renders! David Autodesk VIZ 3 January 16th, 2004 08:10 PM
