Autodesk VIZ Autodesk VIZ
Old May 17th, 2007   #1 (permalink)
prodham's Avatar
Default material and radiosity problem
i am having a very unusual problem processing a radiosity solution on a particular project.
essentially the radiosity solution is crashing every time, even though the settings are good. as a test, i removed all the material maps (diffuse and some bump) and it works fine.
i can't understand this at all. the materials are not out of the ordinary and it is a student project where they are all using the same bitmap files. i have never had this problem before.....any suggestions ?
much appreciated
paul
prodham is offline
Old May 17th, 2007   #2 (permalink)
prodham's Avatar
Default Re: material and radiosity problem
well, i finally solved it, but i'm still at a loss to explain
i removed the mapping on two objects (flags). these objects were extruded regions in autocad and were modeled to look like they were rippling in the breeze.
i'm not sure if the geometry was too complex, but whatever the case it seems to process the solution fine now.
i'm still surprised that diffuse mapping on a material would crash a radiosity solution. i have used this project for hundreds of students and i've never encountered this.
prodham is offline
Radiosity Problem? tcupp Autodesk VIZ 6 April 24th, 2007 11:02 AM
radiosity and chrome material illyrianeye Autodesk VIZ 10 December 13th, 2006 02:11 AM
Radiosity out of Memory problem Barry Milnes Hardware and Technical Discusions 7 December 6th, 2006 09:25 PM
Problem with raytraced reflections and radiosity Rick Eloy 3ds Max 3 November 12th, 2004 10:21 AM
Material Reflectance Values For Radiosity JamesTaylor Autodesk VIZ 3 September 8th, 2004 08:42 AM
