Autodesk VIZ Autodesk VIZ
Old May 29th, 2007   #1 (permalink)
ecastillor's Avatar
Mexico
Default Help! cant find render dialog window....
I press render scene button or hit f10 but to no avail.
I must have pushed the window out of the way some how...
does anyone know how to reset this?
ecastillor is offline
Old May 29th, 2007   #2 (permalink)
United_States  Send a message via MSN to Scotty T Send a message via Skype™ to Scotty T
Default Re: Help! cant find render dialog window....
A while back I had the same prob. I had to give up one of two monitors and when I opened max my system still recognized the missing screen which I would place my dialog windows.
I had to find another monitor and restart max to retrieve the dialog boxes from the secondary monitor.
Dont know if this is your problem but its a thought.
Scott Turner
Scotty T is offline
Old May 29th, 2007   #3 (permalink)
crazy homeless guy's Avatar
Name: travis schmiesing
if it is set up like 3dsmax, you can open the equivalent to the 3dsmax.ini file, and then locate the "RenderVFBPosition" line. it will look something like this.
[RenderVFBPosition]
Position=100 140
the position represents the pixel position of the top right hand corner of the dialog box. make sure it fits within the resolution of you screen. if not, change it so that it does. now save the file, and launch max. it should show up then.
i also read on this board one time that you can simply delete the 3dsmax.ini file, and it will be recreated the next time you launch max, and all settings will be within you monitor, however, i have not tested this method. ...and i guess there is a chance that it will erase some other of you settings.
again, this is for max, but i would guess that viz is set u in a similar fashion.
travis schmiesing
crazy homeless guy is offline
Old May 30th, 2007   #4 (permalink)
ecastillor's Avatar
Mexico
thanx! I found the way in an autodesk forum...
here....
Re: menus are missing!
Use the keyboard to move each missing dialog back onto the screen:
Bring the dialog into "focus" using its keyboard or menu item.
Hold ALT and hit Space bar.
Hit the letter M (move)
Use keyboard arrow keys to return it into view.
Old May 30th, 2007   #5 (permalink)
gfa2's Avatar
I have this happen all the time because I have 2 monitors at the office, but when I'm at home using my laptop to VPN into my office computer, sometimes there are dialog boxes over on the other monitor that I can't see on the laptop. Here is a handy little program I found to help with this problem. It will force all open programs or dialog boxes to pop onto the single viewable monitor. I used to use that Alt -> spacebar -> M technique but this is WAY faster and foolproof which is perfect for me .
gfa2 is offline
Maxwell Render 1.5 Maxer Maxwell Render 205 August 4th, 2007 12:59 PM
Weird Render Error?? AFK_Matrix 3ds Max 2 May 9th, 2007 03:34 AM
Viewport and region render aflack 3ds Max 2 October 20th, 2005 02:30 AM
Render Elements - Shadow muzzy 3ds Max 5 October 25th, 2003 02:47 AM
cinema 4d PiNkFlUiD Finished Work 13 February 28th, 2003 04:00 AM
