Old May 29th, 2007   #1 (permalink)
Name: Rune Jørgensen
Denmark
Default Network help
Hi, i am trying to make two machines render 1 single image, but when i start the manager from the main machine it says "Connection from computer in Localhost refused"?
Does anybody have a quick setup guide or explaination on how to set up network rendering
turbo2000 is offline
Old May 29th, 2007   #2 (permalink)
Maxer's Avatar
Default Re: Network help
It's pretty simple; you need to be running the manager program before you start any of there server programs up. If you have a dedicated machine that you can run the manager program on that is the optimum situation but if your also going to want the machine running the manager program to render then you'll also need to start up the server app once the manager app is up and running. You will need a place to store your MXS and MXI files, that means you'll need a folder that all your machines have read and write access to over your network. Once all that is in place start up the Maxwell viewer (MXCL -d) select the network tap, click on connect and all the available server machines will show up.
“There is no spoon”
Maxer is offline
Old May 30th, 2007   #3 (permalink)
markus groeteke's Avatar
Germany
another detail: just don't forget to open firewall ports 51912, 23496-23503 for network rendering on maxwell.
good luck
markus
3dworks visual computing - berlin, germany
www.3dworks.com
click here for more images
markus groeteke is offline
Network Diagrams/Configurations himom Hardware and Technical Discusions 1 November 2nd, 2006 08:21 AM
Request: Network Rendering How To For Beginners thickly Hardware and Technical Discusions 1 November 1st, 2006 11:00 AM
Vray rc3 & max9 network rendering prob philip kelly VRay Render 4 October 31st, 2006 10:09 AM
IES Erco lighting network render nightmare... alfienoakes Autodesk VIZ 9 February 24th, 2006 09:15 AM
network rendering... anvaraziz Hardware and Technical Discusions 3 July 1st, 2004 07:44 PM
