Autodesk VIZ Autodesk VIZ
Old September 9th, 2002   #1 (permalink)
versionseven
Guest
Posts: n/a
Name:
Exclamation
Is there any way to render a interior scene in Viz with 200 photometrics lights without crashing the computer.
I need to use that many lights because we are doing a lighting study of the dome in a palace.
Please advise.
Old September 9th, 2002   #2 (permalink)
plastic's Avatar
Austria
define crash...
probably you have not enough ram. you can increase the radiosity meshing size to reduce memory consumption.
Marc Lorenz
http://plugins.angstraum.at
My 3d gallery at Flickr
plastic is offline
Old September 11th, 2002   #3 (permalink)
versionseven
Guest
Posts: n/a
Name:
There is no problem doing the radiosity calculation, but when I render the actual scene, it stops after rendering partially.
Any advice?
Old September 12th, 2002   #4 (permalink)
abicalho's Avatar
Choose Re-Use Direct Illumination in the Radiosity dialogue.
That option will render the direct illumination from the Radiosity mesh and won't re-process shadows and lights. This will make the renderer more memory efficient, but you may lose precision on your shadows.
Alexander | discreet Quality Engineer
Alex Bicalho
abicalho is offline
