Autodesk VIZ Autodesk VIZ
Old June 22nd, 2007   #1 (permalink)
trhoads's Avatar
Default grouped objects
I have not been on here in ages, and have not been working in VIZ much either. But I recently bought a package of cars, and today went to use one and found that a few objects in the file are grouped together, and some of them are incorrectly grouped. I need to find out how to fix this problem, either by ungrouping them, or assigning a material just to one piece of the group. I am not familiar with how to do this in VIZ, any advice or help would be great.
I am attaching a screenshot, to show the problem. There is one body panel of the car, is grouped with some other parts, and the one body panel is the original color, and I want to change it. I am just stuck, it is over my head, so I turned here for help. TIA.
I am trying to drink away the part of the day that I can not sleep away.
trhoads is offline
Old June 22nd, 2007   #2 (permalink)
Chad Warner's Avatar
Default Re: grouped objects
If they are incorrectly grouped to begin with, what I would do is select the group, then in the menu bar, look for the "group" menu. Go to the "explode group" option, which will get rid of the group. Then you can apply the material as needed to the object. Once this is done, select all the objects that want to be part of the new group, go to the group menu, and choose "group" which will then ask you for a new group name.
Chad Warner is offline
Old June 22nd, 2007   #3 (permalink)
trhoads's Avatar
I just gave that a go, and I don't have the option to "ungroup", it is not in bold, and I can't select that.
I did find, that there was a separate material in my material editor, that was the same color as the primary car body material, and it is assigned to that piece. weird, yeah. I did find another car in the package that has the same issue. the solution was there, I just had to find it.
thanks for the tip, I will remember that for the future.
trhoads is offline
Applying an image to multiple objects. sezbod Cinema 4D 2 April 19th, 2007 11:36 AM
simplify a model? Robeast Autodesk VIZ 7 May 19th, 2006 05:30 AM
baked radiosity too bright for some objects ava 3ds Max 1 April 3rd, 2006 04:29 AM
Objects Utility Needed for Max/Viz cgarchist 3ds Max 3 November 23rd, 2005 12:46 AM
Hiding Objects in C4D manepalli Cinema 4D 2 November 26th, 2004 09:12 PM
