Old July 1st, 2007   #1 (permalink)
Croatia
Default Caustic efect, how?
Hi there! I am using maxwell for some time and it seems I cant get caustic effect. How can I get caustic on my render?
Here is render at which I want caustics.
Please help!
bheware is offline
Old July 1st, 2007   #2 (permalink)
AJLynn's Avatar
Default Re: Caustic efect, how?
You've got caustics, they're just really diffuse. You'll need more direct light to get sharp caustics.
AJLynn is offline
Old July 1st, 2007   #3 (permalink)
Croatia
Oh, I do? Hmm, I guess caustics depends on SL? Right? How high SL must be than?
bheware is offline
Old July 1st, 2007   #4 (permalink)
AJLynn's Avatar
That varies. But this is, what, skydome lighting? You're only going to see very weak, diffuse caustics however long you let it render.
AJLynn is offline
Old July 2nd, 2007   #5 (permalink)
dave davidson's Avatar
United Kingdom  Send a message via AIM to dave davidson Send a message via MSN to dave davidson
try a cube as an emitter inside an open cone ( with the normals facing inwards) that is reflective to act as a spot light and aim it at the objects, this will give you caustics that will show up fast
www.max3d.org
cinema 4d xl v9. dual core 4400, 4 gig ram, 2x sli 7800gtxs, dual 21" lcds. etc etc
dave davidson is offline
Old July 2nd, 2007   #6 (permalink)
Croatia
you mean, cone cut by 180°? ok, i will try that. thanks.
whoever has a suggestion can wirte.
bheware is offline
Old July 2nd, 2007   #7 (permalink)
Croatia
no worries, i got it. its not with cone and cube.
bheware is offline
Room illuminated with caustic karian Work in Progress (WIP) 0 September 9th, 2006 04:46 PM
Caustic test Asim Harbas Work in Progress (WIP) 4 December 24th, 2003 02:03 AM
