| Autodesk VIZ Autodesk VIZ |
Name: Daffydd Morgan |
Hi all,
Would someone please point me in the direction of a tutorial so that I can learn to create a chair back like the one pictured here: http://www.greatwindsorchairs.com/co...hair_ss-pu.htm Just the chair back - the rounded back and arms. I think it's a loft?? But I don't understand how to get the arms to go in another direction. I can create a simple loft - but I'm really stuck. I may even be wrong about it being a loft? I'm terrible at modelling! I'm using Viz 2005. Thanks so much! Daf
My humble gallery: Dreamscraps Studios |
Name: Martin Norris |
It could be a Loft, the shape can be scaled along certain axis, and moved exentrictlly fom the path, its posible, also, you could use a two shape loft, so you could have lots of variatiation with that tool. If I where you I would play a little with the deformtions on the loft modiefiers palette, try adjusting curves, smothing them, adding vertexes, etc.
Good luck |
Thank you, chiquito!
I was able to get the shape I wanted by "playing" with some of the options. Woohoo! I learned something about modelling. Now I have another related question. I thought it would be easier to get the shape I wanted with "half" the object - that way I didn't have to exactly duplicate the pattern/design - and then I could mirror the spline for the other half. Well - the mirror worked in that I now have 2 identical halves but ... I'm not able to loft the 2 halves. I attached them together but ended up with 2 first vertice - I think that is why the "get shape" is grayed out. I can't figure out how to completely attach the 2 halves with just one 1st vertex. I read somewhere about a symetry modifier but I don't think my version of Viz (2005) has it ... Thanks for any help with this! Daf
Name: Tom Livings |
Well you could complete the object half (with loft or whatever) and then mirror the completed object.
For this task, I probably would have drawn a shape in 2 d, extruded it, then converted to poly, then bent it into shape...pretty much the way the original was made.
www.3dcom.us |
Thanks, Tom, I'm going to give that a try!
Daf
| Rhino or Max for Modelling Freeform Architecture? | Razorback | Rhinoceros | 10 | February 1st, 2008 09:13 AM |
| What codec for 'Loft Modelling' DVD?? | MarkC-UK | General Discussions | 4 | October 14th, 2006 02:51 AM |
| help needed for arch modelling | haneet khanna | 3ds Max | 2 | May 2nd, 2005 02:53 PM |
| loft, loft and more loft!!!! | radioVOY | Hardware and Technical Discusions | 2 | August 15th, 2004 09:47 PM |
