Old July 25th, 2007   #1 (permalink)
Name: Rune Jørgensen
Denmark
Default Help with simple material
Hi can someone help to create a wall material like this in black
http://whisky-aps.dk/SiteConnect/userimages/-722594502
If it's to any help, here are some measurements:
http://www.corusgroup.com/en/company/divisions/distribution_building_systems_division/corus_distribution_and_building_systems/cbs_nordic/wall_cladding/trapezoidal_profiles/#31008
turbo2000 is offline
Old July 25th, 2007   #2 (permalink)
RTurner's Avatar
Default Re: Help with simple material
Are you modeling the ridges or using bump map? If you can afford it and quality matters, model the ridges, otherwise it will look very flat at the edges. Edit Poly is your friend.
RTurner is offline
Old July 25th, 2007   #3 (permalink)
diegofer_9's Avatar
turbo2000,
I think it depends how close you get to see this material. If it's very close to your camera, I would definitely model it. If it's really far, you can get away with a bump material made of black and white lines, to simulate the ribs, or even with displacement to get more detail. But again, you should think about it in terms of how much detail do you want.
DiegoFer
www.diegoferotero.com
lostrevolution.blogspot.com
diegofer_9 is offline
Old July 25th, 2007   #4 (permalink)
Denmark
Okay thank you both, i am not the big modeller so i guess i maybe have to make a bumpmap for it...
Transluscent Vray Light Material How? kwerch VRay Render 3 April 19th, 2007 01:58 AM
shell material v-cube 3ds Max 1 May 19th, 2006 09:31 PM
mr problem with glass mr material with dielectric msamer 3ds Max 9 April 6th, 2006 11:34 AM
