Autodesk VIZ Autodesk VIZ
Old August 1st, 2007   #1 (permalink)
Default Rendering a floor plan
Hi all,
What's the most effective way to create a floor plan view for rendering in Mental Ray.
Do you place a camera above the building and then clip the view or do you place the camera at ceiling height of the room?
Also, how is this view given light?
cadjockey
cadjockey is offline
Old August 1st, 2007   #2 (permalink)
Default Re: Rendering a floor plan
erm, i've attached one here, not sure if thats what you mean but its a project i'm workin on at the minute, all i've done here is position the floor plan in perspective view, you could add camera if you want, then i just placed a skylight and enabled final gather in MRay and voila. This was jus for my testing tho
daveb867 is offline
Old August 1st, 2007   #3 (permalink)
ok so maybe i'l try and attach the render this time : p
daveb867 is offline
Old August 1st, 2007   #4 (permalink)
Name: ajibade adebowale
I believe in vray you need to have the ceiling on or else you'll have to account for light escaping through the big void.....
make your ceiling non visible to the camera in the properties and you should be good to go.
Even though I am referring to Vray, I would assume the principle applies.
mr. a is offline
Old August 1st, 2007   #5 (permalink)
afterglow's Avatar
i just used the environment light. no ceiling.
rather than rendering top viewport, i set a camera with a tiny field of view, like 1 degree, and shifted it a long way up in Z.
afterglow is online now
Old August 1st, 2007   #6 (permalink)
Name: Michael Michaelides
Cyprus
Hi there i am new to this forum. I have done something which i think is similar to what you want to do.i am sending you the web link of my web site which shows what i have done. Have in mind that i used radiosity with a skylight and a direct light, not mental ray. here is the link check it and i can send you the max file if you want. http://www.3dgs.com/Portfolio/Portfo...ortfolio8.html
Michael
michaelidesm is offline
Old August 2nd, 2007   #7 (permalink)
Timothy Saunders's Avatar
I have done a more finished version of what DaveB posted, but the problem with that is, there are a few walls you end up not being able to see behind. A solution is to make those walls slightly transpatent, but I don't like the looks of that. I think Afterglow's solution is much more useful for the client. The only thing it is lacking is door openings.
Timothy Saunders is offline
Old August 2nd, 2007   #8 (permalink)
JonRashid's Avatar
Wales
I have to produce around 20 of these a month. If you use the light tracer and skylight options - then rendering time is very quick. Attached is sample that can be turned around in a few hours.
JonRashid is offline
Scene optimalization for viewing and rendering zajooo 3ds Max 6 February 26th, 2007 02:53 AM
NEWS: ARTVPS Launch new Rendering Solution with Mental Images Jeff Mottle SIGGRAPH 2006 0 August 1st, 2006 09:41 PM
vray - rendering a distributed render using netwaor rendering seamus VRay Render 3 August 23rd, 2005 03:40 AM
mentay ray exterior rendering (unchallenge) Sirkus The Unchallenge 47 August 22nd, 2004 03:10 AM
Speed up rendering from Mac formZ (PC? 3rd Party renderers?) halcy FormZ 2 June 11th, 2004 11:55 AM
