Old August 6th, 2007   #1 (permalink)
United Kingdom  Send a message via Skype™ to Rendermedia
Default Camera Matching
Hi All,
I am working on a Verified View for a client, the client has provided me with 4 camera positions such as X,Y & Z values,
The problem I have is that when placing these into my scene the cameras do not match up with the development (which I am led to believe is in the correct space XYZ) the figures from my client for 1 camera is as follows
Short Range B - x624523 y234274 z23.6mAOD
however if I select the bottom corner of a building near this camera I have a value of
x1364.323 y3736.223 z23.25
there is no decimal point in the camera values my client gave and I would not expect one as they are using Topographical data and not Max, however these values which i am told are correct are too long at 6 digits, sorry to give you a Vulcan mind meld so early on a Monday morning.
Kind Regards
Mark
Rendermedia is offline
Old August 6th, 2007   #2 (permalink)
Shetland Islands
Default Re: Camera Matching
Sounds like the CAD survey is on it's own grid, the co-ordinates from the client sound like national grid numbers, while the development ones are not.
Maybe see if the surveyor can give you national grid cooridnates for his stations? Otherwise I would guess you are looking at pulling grids from OS maps for a few building corners (survey grid might be rotated too) and fitting as best you can.
colinsmith is offline
Camera Matching maxkid 3ds Max 2 April 4th, 2007 11:44 AM
Matching camera nilariver@gmail.com General Discussions 5 February 24th, 2007 11:52 PM
Camera Matching??? jophus14 3ds Max 10 February 5th, 2007 12:41 AM
Camera Matching Frosty Cinema 4D 1 May 25th, 2004 01:05 AM
Canon G5 camera and camera matching pailhead Hardware and Technical Discusions 4 February 24th, 2004 12:08 AM
