Name: brendan coyle |
has anyone else had this problem with extruding/beveling/shelling an editable spline and having it extrude/bevel/shell in an odd direction. this happens to me when I reuse splines especially for tile building. If the splines are rotates and adjusted I usually get undesirable results when trying to pull them up.
maybe there's a simpler way to fix this instead of just redoing all the spline work. thanks |
Name: Matthew Dartford |
way to fix....
If you have a spline that extudes to the side, and not top to bottom you can simply draw a spline that would extrude correctly, then attach the other spline to it...it will then extrude in the correct direction. |
| 3DS Max Camera Correction Modifier | Claudio Branch | General Discussions | 8 | September 29th, 2008 07:19 AM |
| 3ds max 8 won't launch on Opteron/WinXP64 render nodes | ShaunDon | Hardware and Technical Discusions | 8 | July 8th, 2006 09:16 PM |
| 3ds MAX and W2K SP 4/Hot Fix Issues | Jeff Mottle | 3ds Max | 16 | October 10th, 2003 12:07 PM |
| Discreet 3ds max Extensions | easy | 3ds Max | 7 | December 16th, 2002 11:39 PM |
