Old August 7th, 2007   #1 (permalink)
Default VIZ, Minimum object size?
Hi all,
Im working on a scene with the units in meters. when creating details starting from primitive objects or shapes i can only create them above a certain size. i.e. i cant make a sphere with a radius smaller than about 0.5m.
It get frustrating having to create large objects then scale them.
Is there a setting to change this?
Q-Bix is offline
Old August 7th, 2007   #2 (permalink)
Trevor Tizard's Avatar
England
Default Re: VIZ, Minimum object size?
Change the number of decimal places in the spinners option from the "Customize>Preferences" Tab
Trevor Tizard is offline
Old August 8th, 2007   #3 (permalink)
Thanks,
That hasnt had an effect.
Is there any other setting it could be? it seem to be any object under 80mm.
Q-Bix is offline
Actual object size hbryant Maya 2 February 13th, 2007 12:04 PM
why is one object not one object RAYMOND Autodesk VIZ 4 November 7th, 2005 12:00 PM
combine object by layer rayray 3ds Max 1 July 24th, 2005 10:09 AM
Which Size of Wacom Tablet?? Richard McCarthy Hardware and Technical Discusions 18 February 24th, 2005 09:48 PM
